Old 12-02-2005, 01:13 PM   #1
SOON2BLAZE
SOON2BLAZE's Avatar
blazer hatch lock removal
I need to remove the handle / lock from my blazer hatch to have a key made. Anyone have an idea the difficulty or pitfalls involved? The ignition and door key are the same, were orignal hatch keys diffrent? I had hoped I would be able to give a part # to the local chevy dealer for a new key, but the part counter said thats not possible. A local locksmith will make me a key for $20. if I remove the handle. Any ideas? Thanks
SOON2BLAZE is offline   Reply With Quote
Old 12-02-2005, 01:58 PM   #2
71swb4x4
71swb4x4's Avatar
Re: blazer hatch lock removal
I believe you remove the plate from the back of the hatch, and there should be two bolts holding the latch on. Originally the hatches were keyed the same as the ignition and doors.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-02-2005, 07:17 PM   #3
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
I think the handle is kind of a press fit scenario. Mine wouldn't come apart. Had to take to a locksmith, he took an impression and made me keys.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 12-02-2005, 07:31 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I was thinking there was a locking split ring also, I thought it had
to be removed before it would come loose, I could be wrong.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-02-2005, 09:05 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
When I had a key made for mine I just took the t-handle off the hatch and took it to the key man.. To remove the hatch handle you need to remove the access plate on the bottom of the hatch to get at the pins that hold the hatch rods to the handle. Once you remove those you can remove the 2 flat blade screws from the t-handle it sdelf and the whole thing should slide out...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-02-2005, 10:47 PM   #6
SOON2BLAZE
SOON2BLAZE's Avatar
Thanks for all the info guys!
Old 12-04-2005, 01:58 AM   #7
cheyenne10
cheyenne10's Avatar
I concur with others advise, its a quick and easy R/R. You might be suprised when getting key made that it matches your ignition/doors!! The one I did on 72 the locksmith used a garage door/gas cap type key and on a whim I tried my ignition key and it fit like a dream. Locksmith lubed and cleaned up lock which is why original key failed when I bought truck. Needless to say I scraped the aftermarket keys and used good copies of the ignition key.
Still have sellers remorse on that truck but its still lurking here under another board members signature. Thats a truck on its 3rd board member.
Bob
cheyenne10 is offline   Reply With Quote
Old 12-04-2005, 07:27 PM   #8
SOON2BLAZE
SOON2BLAZE's Avatar
Thanks for the tip Cheyenne10!!! I went out and cleaned up the lock mechinism, put in a little lube and the damn thing works,using the door/ignition key too! Thank you all for your posts.
