chevy truck fan
Radi. Core Support Bushing Questions
well i am now in the process of trying to put on the radi. core support to the frame. i bought the energy susp. kit for my truck & the body bushings worked great. i am not having such great luck with the radi core support though.
![]() ![]() ![]() thanks for the help in advance!!! rodstored-72 |
No,I DON'T have Tourett's
Re: Radi. Core Support Bushing Questions
I just installed a prothane body mount kit on the blazer. I noticed the same thing, bushings are smaller than hole in radiator support. I don't think it will matter much as the bushings are designed mostly for vertical loading and not so much for lateral, hence the sloppy fit is acceptable..........I hope.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
![]() Join Date: Jul 2004
The stock ones are the same way, you need some room for adjustment side to side so the front clip centers on the bumper and frameand some fore and aft adjustment to line up with the cab and doors.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
chevy truck fan
green machine
you are probably right. it just seems that with that much room the support would be easy to push one side to the other. what keeps the support from doing that??? thanks for your responses. please keep them coming! rodstored-72 |
I guess when the bolt gets tightened, there must be enough clamping force to keep it from sliding around ???
chevy truck fan
well,
i am going to go to ricks pickup parts (in mesa) this afternoon & compare my bushings to the stock replacement ones. if there is know difference then you guys are right. if there is a difference then i will buy the stock ones & then see about getting some money back from the place where i bought the poly ones! thanks again for the responses!!! rodstored-72 |
