Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 12-05-2005, 11:37 PM   #1
g_goble1967
front end swap
Hi all, I am working on a 67 C10 stepside that came factory 6cyl 3 on the tree. I will most likely be running a 327/350 hydro. I have a 85 GMC parts truck that I would like to use the disk brakes and rear end (411 gears are horrible on gas) I need to know if I can use the entire frond end from spindle to spindle including the crossmember. I think it should work but I really need to be know before I take my truck apart. should I just use the spindles and forget the rest? Any help is greatly needed.
Thank you,
G_Goble
g_goble1967 is offline   Reply With Quote
Old 12-06-2005, 12:07 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: front end swap
Welcome to the board from South Mississippi. You can use the entire crossmember, it's a cheap way to upgrade your brakes. I'm about to do the same thing myself. Check out our FAQ board for lots of good info.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-06-2005, 12:12 AM   #3
g_goble1967
Re: front end swap
Thanks for the info. I'll start working on it this weekend.
Old 12-07-2005, 12:50 PM   #4
Yukon Jack
Yukon Jack's Avatar
Re: front end swap
Welcome - keep us posted on your project.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-08-2005, 10:07 PM   #5
Rydn2L0w
Active Member
Rydn2L0w's Avatar
Re: front end swap
welcome from Orlando
Rydn2L0w is offline   Reply With Quote
Old 12-15-2005, 04:48 PM   #6
Liz
Catchy title goes here..
Liz's Avatar
Re: front end swap
Liz is offline   Reply With Quote
Old 12-15-2005, 05:39 PM   #7
jsbgump
Gone Fishing
jsbgump's Avatar
Re: front end swap
welcome from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
