07-12-2002, 12:03 PM | #1 |
14.1 @ 96MPH
Replacing blower motor?
Just wondering if there's any tips or tricks to it. My dad remembers it being a royal pain last time but I don't see why and he doesn't remember why.
Maybe that's why I've gotta replace it. Factory A/C if that makes a difference, it probably does...
Project1970 - LS1 Swap Complete! |
07-12-2002, 12:49 PM | #2 |
CCRider
You are testing my memory, but it seems I remember one of the bolts that hold the blower motor in on a/c trucks is blocked by the hood hinge. I am almost sure I had to remove the hinge to get it out.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
07-12-2002, 12:54 PM | #3 |
I had to take the hinge off (not to mention the hood). Maybe there's a trick to it but I didn't see it.
Good luck!
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
07-12-2002, 07:02 PM | #4 |
I could get the top ones without a problem, it's the one buried down behind the passenger fender that was hard. A previous owner cut a hole in the fender, made it easy for me.
07-12-2002, 08:57 PM | #5 |
Use something to prop open the hood, scratch marks where the bolts go on the hinge so you can line up the hood properly when you replace the hinge. Its REALLY EASY, Give it a go.
07-13-2002, 05:29 AM | #6 |
14.1 @ 96MPH
*eeps*
The hinge? I've gotta remove the hinge? Oh well, now's as good as time as ever to realign the hood. I can't take driving around Phoenix without A/C anymore!!!
07-13-2002, 10:23 PM | #7 |
14.1 @ 96MPH
Oh, and forgive me if this sounds utterly retarded - what's the preferred method for supporting the hood? A two-by-four from the latch to the radiator?
07-13-2002, 10:43 PM | #8 |
its all about the +6 inches
Thats how my hood has been held open every time for the last 1 1/2 years. Well, Actually I just fixed it.
07-13-2002, 11:54 PM | #9 |
I guess it's just the way I did it, but I'm unsafe type of person. I just undid the passenger side hood hinge from the fender and slid it forward and let it rest on the inner fender.
07-14-2002, 12:37 PM | #10 |
hahaha
Did you make sure that it was not just a bad ground on the blower first, like mine was? If it is it sure saves alot of work. I recomend checking it out fully prior to the change. Sometimes, I will jump to fast and wind up replacing something that works.
Joker69
69lwb, 29 A coupe hotrod, 55 chevy hardtop, |
07-14-2002, 05:09 PM | #11 |
14.1 @ 96MPH
It runs, but it draws way too much current. Kills switches all the time.
07-15-2002, 08:22 PM | #12 |
Thats how I have always done them, remove the hindge and prop the hood --piece of cake
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
07-16-2002, 05:33 AM | #13 | |
14.1 @ 96MPH
So now I've got a new blower motor and an aligned hood.
07-16-2002, 10:13 AM | #14 |
Replaced mine last winter. The neighbor just happened to have received a flex screw driver for Christmas. The shaft is bendable, kinda like some desk lamps. You can put sockets or screw driver tips on it. It worked great. Didn't have to touch the hinge.
