Insert Witty Text Here
New Engine-What size balancer?
I am about to order a crate motor from Summit. It says it comes with timing tabs for both sizes of balancer. What should I get?
I'm not sure what size the original 305 has. I'm not re-using the balancer. It has a groove worn in it, and so does the sleeve a previous owner put on it. ![]() Will my stock pulley fit regardless of size, or do I need to match what is already on there? Summit lists a 6 3/4 in their "suggested parts" section, but does not say why. Thanks, Slonaker |
Re: New Engine-What size balancer?
My truck is at the body shop right now having the frame aligned or I would run out there and measure it for you. If memory serves me correctly (and its been failing me here lately
![]() ADDED: Just out of curiosity I looked on the GM web site at their crate motors and engine parts. I noticed that they recommend the 6 3/4 inch balancer for the 305 and 350 engines. The 8 inch balancer is used primarily in racing applications. Beyond that I don't know why they would recommend one over the other.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado Last edited by crawdad; 12-06-2005 at 06:15 PM. |
Thanks. That's good to know.
Slonaker |
Parts and more parts
Aftermarket balancers come in all sizes. I have had both on a 350 motor and had no problems. I presently have a 6 3/4 balancer on the 383 stroker motor and it works fine. the last stroker had a larger Fluiddampener on it.
Real Men Wear Orange
I'd guess, going by basic physics, the bigger the better if it has a lot of power. If it's going to be running fast or hard, get a bigger one.
~Rest In Peace~
get the 8 inch dampfluid balancer
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
~Rest In Peace~
http://shop.enginekits.com/osb/itemdetails.cfm?ID=353 check this place out
Check www.ebaymotors.com for ZZ4 balancers. There have been some new take-off balancers on there in the $50 range recently, and the ZZ4 units are 8" diameter and have degree marks etched in them.
Sorry I missed the responses from the last of you guys. I ordered the parts early this evening.
I ordered a Goodwrench 260 hp 4 bolt main 350, a Summit branded stock 6.75inch balancer, a Summit branded SFI approved flexplate, a Mallory HEI, a set of Moroso wire looms to route the plug wires under my exhaust manifolds, and the necessary gaskets to put everything together. Kind of scary spending this much money. I told my wife I have never spent this much money at one time without getting a whole truck or a house or something out of it. ![]() Thanks for the info, everyone. Slonaker |
No No
A 350 comes from the factory with an 8in dampener. A 6in (305) dampener reduces rotating mass and is supposed to let it rev a tad better. It doesent really matter as long as the timing tab is aligned correctly. a GM stock performance upgrade on the cheap would be any TPI Z28/TA dampener.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
