Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 12-08-2005, 12:30 AM   #1
matt67350
matt67350's Avatar
headlight relay install
I did this to my trucks after reading this:
Brighter Head Lights @ madelectrical.com. http://www.madelectrical.com/electri...adlights.shtml
1 Read the artical
2 Parts list 2 bosch relays, spade connecters, wire, and inline fuse.
3 Look at wiring sheet
4 Decide that you can do this
5 Start by finding the 14LG and the 18LT wire on the back of the left headlamp.
6 Disconnect the (-Neg) battery cable. Mount the relays to the core support above the horn. You may have to make room for them.
7 Follow the 14LG wire towards the fuseblock. Mark it. This is the one to cut.
8 Follow the 18LT wire towards the fuseblock. Mark it 1st. Cut this one also.
9 Do the wiring:
cut 18LT (or low beam) and run the wire from the fuseblock to Terminal 86 on the relay.
run the other end and that comes from the headlamp plug to Terminal 87 on the relay.
cut 14LG (or hi beam) and run the wire from the fuse block to the Terminal 86 on the 2nd relay. run the other end to Terminal 87 of the 2nd relay.
10 Terminal 85 goes to ground.
11 Run a heavy wire (12ga.) from + Battery Post to Terminal 30 of both relays. Just run it through the stock wiring across the radiator. Add a inline fuse on this one.
12 make sure every thing is connected, secure wires,
replace (- battery cable )
13 Enjoy Brighter Head Lights
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline
Old 04-30-2006, 09:40 PM   #2
jugadro
that's right!
jugadro's Avatar
Re: headlight relay install
Will this stop my headlight dimming when I stop at a stoplight? Man is that annoying.
70-K20-4X4
jugadro is offline
Old 05-29-2006, 12:13 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Already gone, your new lights will work, but they'll work better with this mod. Also, this mod reduces the amount of amps going through the harness, into the cab, through the headlight switch, through the dimmer switch... so they all have less of a load. It increases the amps at the bulb, sop they burn way brighter.
jugadro, this won't stop the dimming all together... you should look into an upgrade on your alt to stop that.
Longhorn Man is offline
Old 03-14-2006, 04:53 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I'm going to put a new Painless Wiring Harness in my truck. Will I still have to do this relay thing so my Tri_Bar headlites will work like they are supposed to.?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Closed Thread
