12-09-2005, 12:33 AM | #1 |
Gaskets for Edelbrock carb/intake?
I am going to be needing the gaskets for my edelbrock carb and intake swap on my 350, but am not sure what to get. The engine is an early 80's 350, the intake is a non-EGR edelbrock performer, and the carb is an edelbrock performer 600CFM. I need the gaskets for the sides, the one for under the distributor and the one for under the carb. I like Fel-Pro gaskets, but am not sure what set to get. Anyone have any model numbers or anything? Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
12-09-2005, 01:17 AM | #2 |
Gone Fishing
Re: Gaskets for Edelbrock carb/intake?
just get the stock felpro gaskets for a early model sbc
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
12-09-2005, 05:01 AM | #3 |
Edelbrock now sells intake manifold gaskets designed specifically for their intake manifolds. Before they started selling gaskets, they recommended using thick gaskets made by Mr. Gasket or Felpro. They recommended against using the thin blue gaskets that Felpro makes because they aren't squishy enough for the aluminum manifold.
12-09-2005, 09:37 AM | #4 |
Mr Gasket is the man!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
12-09-2005, 03:58 PM | #5 |
I use a Felpro #1205 with my Edelbrock intake, just throw away the cork end strips and use a nice bead of RTV, should work just fine.
67 SWB |
12-09-2005, 10:16 PM | #6 |
Use the Edelbrock #9266 divided heat insulator gasket to mount your carb.
I installed one of these on Putter's and one on mine. He has a 1406 on a Performer intake and I have a 1406 on a Performer RPM. We both had problems with hot restarts, but not now.
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside Last edited by GMan69; 12-09-2005 at 10:18 PM. |
12-10-2005, 12:54 AM | #7 |
So, if I order the edelbrock #9266 carb gasket and the #7201 intake gasket set, that should be all I need correct? I never use those rubber or cork front rear gaskets, as they always seem to leak. A nice thick bead of RTV seems to do as well as anything in that situation.
Winktim, is that felpro #1205 a thick gasket or thin? I've used the blue felpro thin gaskets before, but have never used the thick ones.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open Last edited by muddpile; 12-10-2005 at 12:55 AM. |
02-02-2006, 01:45 PM | #8 | |
02-02-2006, 01:56 PM | #9 |
67-72 Addict!
I just bought an edelbrock gasket (thick) to try under my Demon. Haven't installed yet.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-03-2006, 01:17 AM | #10 |
I ended up going with the Felpro Performance Intake gasket set and a 1" phenolic carb spacer with a thin gasket on top and bottom. Haven't had a chance to put it all on yet, but it looks like quality stuff.
12-10-2005, 02:21 AM | #11 |
I assume pretty well any SBC gasket set will work, its just some likely work better with the way aluminum shape shifts.
