Old 12-09-2005, 10:24 PM   #1
76bonanza
76bonanza's Avatar
stumble
At about 30-45 mph if I mash it I get a bad stumble from dead stop good if I slowly stomp it also good? What are the most obviose things?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-09-2005, 10:35 PM   #2
Jimbotronics
YA YA
Jimbotronics's Avatar
Re: stumble
my guess would be clogged fuel filter or carb jets or possibly timing a little off.
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 12-10-2005, 12:18 PM   #3
jhow66
jhow66's Avatar
Re: stumble
What kind of carb-what is time set at-start this all at once--how old is carb?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-10-2005, 12:50 PM   #4
76bonanza
76bonanza's Avatar
Re: stumble
holley carb 3310 not sure how old it is not new not nasty old. I think timing is around 12intial I have no idea what total timing is tho. Also It seems like it only does it when it is cold or it is worse when it is cold. Could it just be the weather? Also the carb is on the rich side not super bad but enuf to notice.
1968 c10
lowered 3" 4"
Old 12-10-2005, 03:15 PM   #5
jhow66
jhow66's Avatar
Re: stumble
Your biggest problem is then with your choke. Is it hooked up--what kind (electric or manuel)? 12* initial should be ok-total timing would not come to play here.
Old 12-10-2005, 03:31 PM   #6
76bonanza
76bonanza's Avatar
Re: stumble
electric choke yes it is hooked up.
1968 c10
lowered 3" 4"
Old 12-10-2005, 11:04 PM   #7
70 Bowtie
Re: stumble
I had a simular problem with my 67 chevelle, It turned out to be a bad plug wire,and a vacuum (sp) leak around the bottom of the carb! Took care of the problem!!
Brett
70 Bowtie is offline   Reply With Quote
Old 12-10-2005, 11:15 PM   #8
jhow66
jhow66's Avatar
Re: stumble
Your choke is set to lean for cold weather. Have someone to set the choke pull-off so it does not open the choke as much when engine starts.
Old 12-10-2005, 11:28 PM   #9
76bonanza
76bonanza's Avatar
Re: stumble
so should I rotate the choke toward front to make it come off sooner. Or to the rear to make it stay on longer?
1968 c10
lowered 3" 4"
Old 12-11-2005, 01:27 AM   #10
jhow66
jhow66's Avatar
Re: stumble
Just set it richer a little at a time until it runs like you want it. Does it fast idle now when choke is on?
Old 12-11-2005, 12:51 PM   #11
jhow66
jhow66's Avatar
Re: stumble
Ok-just keep setting the choke a little richer until stumble stops. If it doe not stumble when hot the problem is with your choke.
Old 12-11-2005, 04:52 PM   #12
Fatback
Fatback's Avatar
Re: stumble
Sorry....I didnt see the cold weather post.......nevermind.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Fatback is offline   Reply With Quote
Old 12-11-2005, 01:46 AM   #13
76bonanza
76bonanza's Avatar
Re: stumble
yes
1968 c10
lowered 3" 4"
Old 12-11-2005, 10:01 AM   #14
Fatback
Fatback's Avatar
Re: stumble
Did you just install the the carb? or have you been running it and this just start. It sounds like a lean condition as jhow66 suggested the choke.or maybe a lean condition cause by an accelerator pump issue. I had a similar stumble with a Holley and had to adjust the screw on the accelerator pump arm. Also, Holley makes an accelerator pump cam assortment that is almost essential in tuning a Holley for around $20 I think.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Old 12-11-2005, 11:23 AM   #15
76bonanza
76bonanza's Avatar
Re: stumble
No I did not install the carb. I know the accelerator pump screw you speak of but never know how to adjust it shorter or longer. I also just today replaced a leaky brake booster?
1968 c10
lowered 3" 4"
Old 12-11-2005, 04:56 PM   #16
76bonanza
76bonanza's Avatar
Re: stumble
hey fatback about adjusting the spring deal on the accelrator pump how does it work? If I make it longer or shorter what does it change.
1968 c10
lowered 3" 4"
Old 12-11-2005, 05:12 PM   #17
jhow66
jhow66's Avatar
Re: stumble
What you want to do is make sure that the pump arm moves at the EXACT same time as your throttle arm does. If it does not this will cause the throttle blades to open before the pump can delivered a charge of fuel from squirtors to cover the extra air that is flowing by the open blades--hence a lean stumble. Check it and if it does not just lengthen the spring by holding one end of bolt and turning nut until it touches lever.
Old 12-11-2005, 06:24 PM   #18
76bonanza
76bonanza's Avatar
Re: stumble
ok there was some play in the spring thing made it a little longer, nice and tight now and moves with the throttle like a mirror . Question about those cams my friend brought so by to me how do you decide which one to use what is the thinking here looks like some make the pump deliver the whole shot faster and some make it slower? But not sure how to determine what each one will do?
1968 c10
lowered 3" 4"
Old 12-11-2005, 09:16 PM   #19
Fatback
Fatback's Avatar
Re: stumble
http://aolsearch.aol.com/aol/redir?s...t+a+carburetor
Here is some info......It's important not to push the pump lever too far. You should be able to move the arm.015-.020 at WOT.The reason is the pump arm can rupture the diaphram. Also a little adjustment on the pump lever can go a long way...so loosen it about 1/4 turn then test drive it. As far as the cams....it was trial and error for me.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Old 12-11-2005, 09:53 PM   #20
Frizzle Fry
Frizzle Fry's Avatar
Re: stumble
Each pump cam is two sided. Before you buy a cam kit, you can flip the one that's on it now and see how that does (given the other side is bigger). They wear out and chances are the side you're using now is worn.
Also, the 3310 is a vacuum secondary carb. You might consider getting a Holley vacuum secondary spring kit (PN 20-13) and adjusting the secondary opening rate by replacing springs. Go heavier until the quick open WOT bog condition goes away.
Why did this show up in colder weather? Maybe you were marginal to begin with and the denser air makes it worse? Just my two pesos.
Frizzle Fry is offline   Reply With Quote
