Old 12-11-2005, 11:00 PM   #1
1969burb
heater control repair non ac
I pulled my control apart to see why the levers were loose, and found all four rivets? that hold the main support body for the cables were pulled away from the face plate. I did not have a support on the rear of the control, but i am assuming there was something there from the factory. Does anyone know of a way to resecure this without drilling holes through the faceplate for new rivets or nuts/bolts? I don't know if this type of metal would take welding of any kind. I found a couple of these controls in trucks at a local wrecking yard and they all had the nut/bolt repair already done to them. I'm sure it works just fine, just ugly to look at. So i'm obviously not the first one to have this problem. any suggestions would be appreciated. thanks, steve
1969burb is offline   Reply With Quote
Old 12-11-2005, 11:14 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Re: heater control repair non ac
I've tried almost everything I could think of, but I ended up drilling holes and using small machine bolts and nuts on the one in my truck. It works good and doesn't look too bad and it's a lot cheaper than having to buy a new assembly. Just my .02.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-11-2005, 11:59 PM   #3
krue
Designated A-hole!
krue's Avatar
You can't really do anything with the pot metal the originals are made of in my experience. I may be wrong tho, I hope so cuz I got the same problem ya'll do.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-12-2005, 12:03 AM   #4
jhow66
jhow66's Avatar
Get some small "button" head bolts in stainless. Polish and they will blend right in-will look nice as they use a allen wrech.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-12-2005, 12:11 AM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
isnt there a repair kit for that ? i seen sum kinda repair kit a Tims Christians shop but i dont remember what all was in it ? i know there was arms and a new face plate but cant remmeber what else was in there
tnblazerk5 is offline   Reply With Quote
Old 12-12-2005, 12:47 AM   #6
1969burb
all of the kits i have seen have levers and new sticker/trim for the front of the panel, nothing to make the repair i need. I might try to use rivets through the face since the heads would be fairly shallow, then use something to space up and apply the new trim from one of these kits.
Old 12-12-2005, 01:55 AM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=179952
I drilled,and tapped mine from the back side. I cut the screws flush. The new face sticker covered everything.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 12-12-2005, 02:55 AM   #8
krue
Designated A-hole!
krue's Avatar
Cool.
www.daveramsey.com
Old 12-12-2005, 06:03 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Countersunk rivets, then the new face plate over them.
Use an AN426AD4 rivet
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-12-2005, 07:59 PM   #10
muddpile
muddpile's Avatar
So, are those repair kits mentioned in the other thread worth getting? I have one broken lever, and the background is dirty, but the bezel is fine and everything seems tight.
muddpile is offline   Reply With Quote
Old 12-12-2005, 08:43 PM   #11
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Mine did that same thing right before the first snowfall
I just drilled holes in mine and pop rivited it back together. It looks ok
But works great
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 12-12-2005, 09:47 PM   #12
jhwkns
Registered Cruiser
jhwkns's Avatar
I thought the kit was overpriced, but the results are nice..
Old 12-12-2005, 11:03 PM   #13
Solver
Solver's Avatar
I have had the same problem a couple of times.
Most of the time the back of the original rivet is still there just the flange is gone. I use a really large drop of JB Weld on the back side of the rivet and alittle extra around the area. it"s kind of like rebuilding the back of the original rivet. So far It has worked well for me and I have done 2 or 3 like this.
Might give that a try before drilling the face!!
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-12-2005, 11:11 PM   #14
1969burb
this is why this board is so great! ideas abound! thanks for all the replies. was there some kind of factory support for the rear of the control?
Old 12-13-2005, 01:43 AM   #15
CG
BlahBlahBlah
ive gone the jb weld route also and it worked fine. while you have it all apart its a good time to lube those cables and pivots.
Old 12-13-2005, 05:07 PM   #16
soundspecilist
I have been through this several times also. I just bought a whole new unit from Early Classic (GREAT resource for everything!). What I found is the cable that goes to the center lever is under so much tension that it is constantly pulling on the unit, eventually causing the rivets to pull loose. What I did on this new unit is I left the center cable disconnected and it hasn't given me a problem. The other end of the cable is right below the heater unit, easily accessible. So I use the top lever for Defroster/Heater vent split, and the bottom one to control the amount of heat. The center one is just for the fan speed. When the 2 working levers are closed (to the left), there is little or no heat that comes out of it. Once summer arrives, just reach down and flip the door closed that the center one controls to shut off 100% of the heat. Sounds Mickey Moused, but it beats tearing up a $120 heater unit.
'69 GMC C3500 1-Ton, Longhorn, SM465, built 350,
soundspecilist is offline   Reply With Quote
