12-13-2005, 09:31 PM | #1 |
PROJECT 7DEUCE
Painless wireing questions....
I have installed a 18 curcuit 67-72 p/n#10206 painless harness in my blazer and have a few questions for those who have installed these kits..
Where did you hook up the gear indicator light and the heater controll light?? All the acc port on the fuse box are hot all the time is that correct or do I have something hooked up wrong??? Any help would be great...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-13-2005, 09:48 PM | #2 |
Re: Painless wireing questions....
not much help here, but how does it pass through the firewall? is it a bulkhead connection or just wires going through a grommet? and bout how much did that cost?
12-13-2005, 10:00 PM | #3 |
PROJECT 7DEUCE
The wires pass through a bulk head but it is larger than the stock one so cutting is required and the stock taillight harness hole is not used so you have to fill it in with a rubber groument.. Cannot remember price right off the top of my head got it at summit racing though..
12-13-2005, 11:08 PM | #4 |
tie into the dash lights....that way they will only be on when the lights are on.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
12-13-2005, 11:32 PM | #5 |
Thats how I wired mine too.
12-14-2005, 01:40 AM | #6 |
Only things that should be hot with switch off are -brake lights-headlight switch- hazzard lights-dome circuit. Check large pink wire to ing. switch (this wire feeds fuse panel). It should not be hot at ing. switch with switch off. Back side of switch will have Acc. post on it.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
