Old 07-13-2002, 01:07 PM   #1
dbenamati
dbenamati's Avatar
Help mounting armrests please
I got two armrests out of a donor truck and want to mount them in my 67 which never had armrests (Basic metal skins). The mounting bracket in the door has two square holes which a clip or something fits into to screw into. I spent the afternoon at the local auto parts store looking for something that fills that hole like a clipped nut and nothing seems to work, also they have a lot of plastic parts but for this armrest, a metal part would be better. Could someone please look to see what fills the two square holes. I have nothing to compare to and the donor truck is gone. Thanks
Dave
Dave Benamati
Hughesville, PA USA
dbenamati is offline   Reply With Quote
Old 07-13-2002, 01:36 PM   #2
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
I'm pretty sure its a clip nut that fill the hole. I would go to a hardware store and tell them what you are looking for they migt have what you need. Just my .02. Good luck and let us know what you find.......
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 07-13-2002, 01:48 PM   #3
jones
maybe that on of those plastic license plate mounting things would fit.
otherwise you could have a 1/4 in nut tack welded on.
good luck
J
69 C15
86 K20
jones is offline   Reply With Quote
Old 07-13-2002, 02:41 PM   #4
Southpa
Southpa's Avatar
Best bet is to hit the boneyard and look for some doors. Scavenge the hell out of any doors for panel screws, clips, etc. I recently had to hacksaw the armrest off my driver's door, those screws were fused into the nuts.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-13-2002, 02:47 PM   #5
pickupman
pickupman's Avatar
They are called a cage nut. If you can not find anything I carry them new. They are .40 cents each. Thanks Bill
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 07-13-2002, 02:56 PM   #6
photoglg
photoglg's Avatar
What I did then I added arm rests to 69 was use the grove nuts from the door handle control unit, I had replaced the units with new ones. The nuts are the same. You have to punch them out of the unit and snap them into the door
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 07-13-2002, 09:30 PM   #7
dbenamati
dbenamati's Avatar
Thanks...I found a solution
I went to the local Wal-mart tonight to pick up diapers for my kid and walked by those license plate mounting plugs (thanks Jones) and figured for $1.69, it's worth a try. I came home, tapped them in with a hammer and screwed the armrests in, worked like a champ. Thanks again!
Dave
Dave Benamati
Hughesville, PA USA
Old 07-13-2002, 09:59 PM   #8
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Probably will work good until you really tug on the armrest. Lowes used to have all that stuff until they sold out in the past couple of months. No more bins full of goodies.
TERRYP is offline   Reply With Quote
Old 07-15-2002, 09:47 AM   #9
johnnyp
Keepin' It Stock
johnnyp's Avatar
Think you looking for the arm rest retainer nut. It's a plastic square nut for attaching arm rest to door. Chevy Duty at http://www.chevyduty.com/ sells them for $.49ea - part number 19-692
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 07-15-2002, 12:10 PM   #10
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Are those nuts the same for the door panel screws too? If so I know I need some new ones. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-15-2002, 02:21 PM   #11
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
do they really just pop right out??? I need to try that....I thought they were welded in......
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
