Old 12-16-2005, 01:07 PM   #1
C&C Chevy
C&C Chevy's Avatar
Swithed to a hotter t-stat, now..
the truck is running like dog poop. Idles rough and the the coolant temps are all over the place. How would switching out a 180 stat for a 195 stat cause all this?
I'm guessing the computer is trying to adapt to the new stat??
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 12-16-2005, 01:15 PM   #2
beaterC10
Re: Swithed to a hotter t-stat, now..
Unless you have TBI, you won't have a computer.
beaterC10 is offline   Reply With Quote
Old 12-16-2005, 03:57 PM   #3
C&C Chevy
C&C Chevy's Avatar
Se my sig.
capt., 180 stat is all I've ever used in the truck. I was under the impression that 195's were for colder climates.
Anyway, I put a 180 stat back in and the truck is running better.
Robert
Current:
Past:
Old 12-16-2005, 01:37 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
That is weird, the '87 takes a 195 stat.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-16-2005, 04:59 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
doesn't sound like a T/stat to me. It sounds like you have water in that high priced gas that you have. I used to switch to a 195 T/stat for winters and then I got rid of the older truck. I live North of you about 300 miles and I run 180 degree T/stats all of the time. If you don't have a heating problem (due to a really big radiator) then you should not have to swap out the T/stat. If your heater is plugged, then changing will help some. As for your running rough, check for a good spark and then run some gas line treatment in the tank. If it has a EFI setup then put in some injector cleaner. ( The coolant temps are all over the place) Did you use a "Super Stat". If not then what you are experiencing is the T/stat full closed and then it "POPS" off of it's seat and then it is full open. (Run hot then run cooler) A "Super Stat is made to modulate better and then the temp is more controlled. Check with any Auto parts outlet They carry them under their name usually. We have NAPA, Carquest, and O Reilly's around here.
Old 12-16-2005, 05:04 PM   #6
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
The computer controls fuel mixtures by reading engine temprature. The factory is a 195. Now, if a hypertech chip is installed in the ECM it requires a 180.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
