Old 12-18-2005, 11:48 PM   #1
...jasper...
springs & spindles
Well just got my front & rear, springs & spindles in from CCP,took a while. Anyway been wondering how much the old 68s going to drag. The rears getting 5" springs with a 2" axle spacer and the front getting 3" drop springs and 3" dropped spindles. With gas shocks all 4 corners. The tires are 27" tall. Been buzy at work geting ready for a few days off for the holidays. Hopefully I can find time during the holidays to change them out. I guess you call it a 7/6 drop. Do you think its going to drag much ??????
Happy Holidays All !!!
...jasper... is offline   Reply With Quote
Old 12-19-2005, 12:41 AM   #2
SCOTI
SCOTI's Avatar
Re: springs & spindles
Yep, it's going to scrape. It might not be too bad if you drive defensively. I know you'll need to re-route your exhaust up as high as possible.
Leave the front bump-stops in as they will help limit the suspension from bottoming too much & will keep the inner fenderwells off the tires on most bumps/dips.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-20-2005, 11:52 AM   #3
bodydropped
yes you will drag the crude out of ur lcas i say just bag the frt because u wont make it over speed bumps for sure unno about turnin radius becasue 3 inch spindles and 2 inch springs dont mix with 8inch wide wheels
bodydropped is offline   Reply With Quote
