Old 12-20-2005, 01:39 AM   #1
4tiresngas
An American Soldier
4tiresngas's Avatar
Question Antenna in Windshield
Does anyone sell windshields for our trucks that have an antenna in them? I don't want the factory antenna sticking out of my cowl. So, I am looking for other options.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 12-20-2005, 01:50 AM   #2
screamin_c102
screamin_c102's Avatar
Re: Antenna in Windshield
Use a hidden antenna. Several comapanies carry them. I know for a fact that Dakota Digital has them, and I believe I have heard the brand Auto-Loc thrown around here on the board.
I am using the Dakota Digital and have it mounted behind my glovebox.
Linky
screamin_c102 is offline   Reply With Quote
Old 12-20-2005, 01:59 AM   #3
screamin_c102
Heres another Ebay Linky
Old 12-20-2005, 05:36 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or just mount your Antenna under the dash or under the cowl.
Old 12-20-2005, 09:31 AM   #5
byrd
Union Electrician
byrd's Avatar
Longhorn has got on easy way there, but would it help/work to attach a piece of wire to the antenna and then to the cab itself to use the whole truck as your antenna? Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-20-2005, 12:16 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I once had one on the '71 that was just two pieces of wire you taped to the windshield in a hidden location. Don't buy this one! I got better reception without an antenna. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-20-2005, 03:45 PM   #7
70short
I installed an antenna under the cowl, I have it grounded to the cab and I get poor reception. I am also trying to find an alternative.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-20-2005, 05:21 PM   #8
hgs_notes
GEARHEAD
hgs_notes's Avatar
Screamin C10, How do you like the reception on your hidden one?
HG
hgs_notes is offline   Reply With Quote
Old 12-20-2005, 07:55 PM   #9
screamin_c102
HG
Works fine, as far as I can tell. We live in the middle of a valley in the middle of BFE so reception sucks around here no matter what. When I get out on the freeway and towards civilization the reception improves.
It is about as good as the wife Focus.
Old 12-20-2005, 08:16 PM   #10
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I got one of the after market ones that attached to the inside of the windshield on bottom of the passenger side .
Best radio reception I have had in years.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-20-2005, 07:17 PM   #11
Longhorn Man
I had one under the cowl in the old GMC for a while. Didn't ground anything more than what was supposed to be. Had a piece of metal in there with a hole big enough for the Ant mount, had it bolted to the inner cowl, and it was bent over to where the Ant pretty much just laid across the front of the cab. Worked just as good as the one that I replaced it with when that portion of the cab fell victom to rust and the antenna fell into the cab.
Old 12-20-2005, 07:35 PM   #12
GMC Jim
GMC Jim's Avatar
the radio chassis is grounded by the mounting....The anntenna is not grounded!....if grounded ; the reception will range from no reception to very poor.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 12-20-2005, 07:40 PM   #13
Longhorn Man
I thought I had read that somewhere... but wasn't sure. Thanks Jim.
Old 12-20-2005, 11:19 PM   #14
byrd
Union Electrician
byrd's Avatar
Bill, give up some info on this one. I haven't seen the type you refer to,only just the terrible looking stock ones from the 80's. Randy
Zip:40272
Old 12-21-2005, 10:50 AM   #15
72 longhorn BB
72 longhorn BB's Avatar
Putting the antenna element under the dash or cowl stacks the chips up against good reception, because you are surrounding the sensing element with grounded (chassis ground) steel.
With a regular FM antenna, the antenna cable is shielded until its connected to the antenna base.
Thats when the cable shielding ends and is grounded to the body, at the antenna mount. (its also grouded at the radio connector, to radio chassis).
At the antenna base, the center conductor (antenna) becomes unshielded, and depending on the antenna (or wire) length, gets tuned to a frequency.
For FM radios, they usually make it a frequency in the FM band that corresponds to where most stations are grouped.
Also, the right packaging length has to be considered and then a happy medium is reached.
Typically in todays cars, that is about 31 inches, but in our trucks, the antenna was telescoping, so the best frequency could be chosen if you knew how to calculate it.
Speaking of calculations, try this website:
http://www.crompton.com/wa3dsp/hamradio/antcalc.html
Oh cra p, I wrote another book (week b4 christmas, office is empty, boring)
What I am getting at is you can literally make your own hidden antenna just by routing the antenna cable up into the cowl, or under the dash, then stripping back the coaxial cable braided ground, leaving about 31 inches (or whatever you desire) bared.
Terminate the shield to chassis ground and try tucking the conductor wire inside the window seal.
Totally hidden! - hey, and it really works too! - just don't let the antenna conductor touch chasis ground, or you will effectiveky shorten the length of the antenna.
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 12-21-2005, 05:19 PM   #16
Bill72BB
Bill72BB's Avatar
here are some pic of the set up ,don't remember the brand .
BILL
Member DUF Club
Old 12-21-2005, 07:30 PM   #17
49studebaker
49studebaker's Avatar
I have one of the hidden antenna's, I believe it's an autoloc. Works really good close in, fades fast when I head out of town, also, it depends which direction the truck is headed. It's a great idea in theory, but I'd do some research, I suspect not all hidden antenna's are equal.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
