Old 12-20-2005, 12:21 PM   #1
Luvlegs
Luvlegs's Avatar
Question quicky how to on throw out bearing?
I tried searching for some but had no luck.... I have a '72 C10 I6 w/3 on tree - can anyone provide "how to" for changing out the throw out bearing - that's all I'm doing at the moment (I want to drive it while I'm building the new heart for it) - I've done it on stuff that was already torn to pieces but thought I might be able to slip in and slip out without too much trouble (might not be able to get it inside out of the cold!) - I'm hoping I picked up the right one (long v. short) - not sure that's an issue with mine either..... thanks for any input!
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 12-20-2005, 12:36 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: quicky how to on throw out bearing?
You'll need to unbolt the bellhousing from the transmission (there are 4 3/4 inch bolts going into the bellhousing from behind), undo your driveshaft, and transmission crossmember, then slide the whole transmission back so the input shaft comes out of the throwout bearing (making sure you have a jack under the tranny so it doesn't fall on you).
Pull the old bearing off the clutch fork, and slide the new one on. Re-installation is opposite of removal, cept for all the struggling to get the input shaft back into the pilot bushing / bearing, LOL
Oh, guess being a 3 on the tree you'll need to disconnect the linkage right away too.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-20-2005, 12:38 PM   #3
shelby987
shelby987's Avatar
I am new to the saginaw's, but every throwout bearing I have replaced, I have packed with lithium grease and just slid onto the input shaft and hooked it up to the arm.....but I am not sure there is a "quicky in and out" way to do it....I think you will have to drop the trans.....maybe you could pull the drive shaft, lower the trans, and get everything done while the trans is on a transmission jack.....but to do it right, you should probably also replace the pilot bearing......imo anyway (just got done doing this to a jeep actually, what a pita those things are....6 diff. kinds of bolts on the bell housing!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 12-20-2005, 12:46 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It can't be done without pulling the transmission. The clutch release bearing, aka throw-out bearing, slides on the pilot shaft of the transmission. But, you already knew that. The only "quickie" part of it that I can think of, is not replacing the clutch disc and pressure plate. So, in my opinion, there isn't an "easy" way to do the job. Sorry.
After reading the other replies, one thing to suggest: Get a couple of bolts about 5-6 inches long, with the correct thread for the "transmission to bell housing" bolts. Cut the heads off of them, and smooth them up so there are no sharp edges on them. With these long headless bolts in place, you can hang the transmission on them, and slide it into place. It makes inserting the pilot shaft into the pilot bushing much easier, when you're laying on your back, holding up the gearbox. Then, install the bottom bolts, and replace the uppers, one at a time. Just be sure that you don't tighten them up too much. Without a head on them, they can be difficult to undo, if you did.
I once had, okay my first car was, a '54 Ford. It had a "new" clutch and pressure plate when I bought it. Nice words to hear when you're 16. However, after about three months of ownership, I was having trouble getting it into gear, unless I put it in gear and then started it. "Someone" said the throwout bearing was going bad. It had a squeal when you pressed on the pedal and that was the clue. So, after I had left town on New Year's Eve, drove about a hundred miles to go deer hunting on New Years' Day, 1965.....while the Arkansas Razorbacks were playing the Nebraska Cornhuskers for the National Title in the Cotton Bowl.....my throwout bearing was only getting worse. An adult, whom we thought was knowledgeable, suggested something be placed between the rod and the arm, to "push a little harder" on the bearing, as in more leverage or more travel. Bad move. Do not repeat that action. The increased travel only served to break the rivets that held the arm in place at the fulcrum inside the bell housing. With the fulcrum now broken loose, the clutch was obligated to remain fully engaged at all times. Whew!! It's a good thing I had practiced shifting without a clutch....youth does wonders for our abilities, don't it?? Only thing: I hadn't practiced driving in towns with stop lights and railroad crossings, without using the clutch. But, we made it back home and got the car fixed. Dang!! It cost me $25, in 1964, to get a new bearing and the labor to fix the broken part.
Bottom line? Don't replace the clutch and pressure plate without also replacing the throwout bearing.
Member Nr. 2770
Old 12-20-2005, 01:16 PM   #5
boraxman
Keepin an eye out
boraxman's Avatar
No "quickly" on replacing the TO bearing...not a fun job unless you like wrenching.
And you may as well check the clutch componets while youre in there.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-20-2005, 01:59 PM   #6
truckdude239
truckdude239's Avatar
umm are you suppose to pack them with greece? because i didn't lol
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-20-2005, 02:01 PM   #7
boraxman
Keepin an eye out
boraxman's Avatar
No they are sealed unit AFAIK.
ZIP 91351
Old 12-20-2005, 02:05 PM   #8
truckdude239
okay good i was going to be scared it i was suppose to lol
David fuller
2000 Tahoe 5.3l 378
Old 12-20-2005, 03:24 PM   #9
Luvlegs
Luvlegs's Avatar
Thanks all! PO had replaced press. plate etc but didn't do the TOB (I don't know why.....) - soooo I just want to get rid of the sound when pushing in on the clutch - It's just got to get me through until I start the frame off (couple weeks away) and I want to drive it around a bit but it's annoying the way it is....
ChevLoRay - the idea about the long bolts.... nice!
Thanks again all!
1972 C10 L6 3OTT
Old 12-20-2005, 03:28 PM   #10
Russell
Professional Grade
Russell's Avatar
What kind of noise is it making?
Old 12-20-2005, 04:03 PM   #11
Luvlegs
Luvlegs's Avatar
At all times the clutch is pushed in, theres a sound like a HEAVY vacuum leak (when sitting in the cab) - Outside the vehicle, 4 different buds (different times) all said "Throw out bearing" (one was my father and with his 60+ years experience, I have to believe him!) (he'll appreciate that).... It stops the instant the clutch is released.
1972 C10 L6 3OTT
Old 12-20-2005, 04:05 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Fellows, you're scaring him too much.
You do not need to unbolt the bellhousing from the engine. That's an unecessary trip to take
Remove the driveshaft, speedo cable and shift linkage. Now, unbolt the trans from the bellhousing. There will be two forward facing bolts and two rearward facing bolts. The bellhousing can remain attached to engine through the whole deal.
Once the trans is off the bellhousing, reach in and pop a new bearing into the clutch fork. Reinstall the trans.
It's a hour job.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-20-2005, 04:59 PM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
It's a hour job.
That's how my dad and I changed mine before I put in the 700R4, It took us about 2 to 3 hours.... Tx must be a pro
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-20-2005, 04:15 PM   #14
Luvlegs
Luvlegs's Avatar
OK Tx!- I like where this is going now!
1972 C10 L6 3OTT
Old 12-20-2005, 04:59 PM   #15
krue
Designated A-hole!
krue's Avatar
If you do have to pull the tranny, get some 6" starter bolts and cut the heads off to use as Chevloray described. One thing that is helpful is to use a grinder to flatten two sides of the bolt where you cut the head off so u can still turn it with a crescent or channellocks.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-20-2005, 05:02 PM   #16
Luvlegs
Luvlegs's Avatar
On it! Don't stick anything in without having a way to get it back out.... I'll stop......
1972 C10 L6 3OTT
