12-20-2005, 05:56 PM | #1 |
Disc Brake Question...
I am currently rebuilding a 1969 Chevy stepside. My truck is 2 wheel drive and I want to convert the front brakes from drums to discs. Today I found a 69 K5 blazer in a junkyard with the whole disc assembly. My question was will it fit even though the K5 is 4x4 and mine 2x4? Is there any other ways I can make it work? I'm from New York and its very hard to come across 67-72 chevy trucks in good shape. If anyone could help itd be greatly appreciated. Later...
tom |
12-20-2005, 05:58 PM | #2 |
Watch out for your cornhole !
Re: Disc Brake Question...
The 4 wheel drive brakes will not work on your two wheel drive.
Fear not though, the easiest way to convert your truck to discs is to use any 1/2 ton 2wd truck from 71-87. The whole front corssmember and suspension unbolts and will easily bolt into your truck. There have been countless guys on here do this with great success. Plus, the newer trucks are much easier to find for you fellows in the rust belt.
12-20-2005, 06:04 PM | #3 |
ok im gonna look into that. thanks alot man!
12-21-2005, 10:33 PM | #4 | |
that's what i did with my 69, took the whole front crossmember from a 72 c-10. only problem i had was 2 bolts on each side of the frame rails being off just a little so all i had to was grind the holes the out a little and everything was fine. real easy to do. make sure you get the master cylinder, proporting valve, and front brake hard lines from the parts truck. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
12-20-2005, 06:19 PM | #5 |
You could also use conversion spindles from just about any of the vendors here, then use the rotors, calipers, etc., from donor trucks like TxFirefighter mentioned. That is what I did, got the spindles from GMC Paul's.
67 SWB |
12-20-2005, 06:51 PM | #6 |
hey thanks man.
12-21-2005, 04:14 AM | #7 |
1969 and 1970 K5 Blazers had Drum front brakes.
Why don't you just swap over the entire 4x4 front end and convert that puppy. A nice 4x4 stepside would be COOL!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
12-21-2005, 12:29 PM | #8 |
itd be nice to do a conversion but my plans are to drop it and 4x4 will be just more of a pain in the ass for that. plus im probably not gonna use 4x4 because i dont want to go offroading and its not gonna be driven in the winter. later...
tom |
12-21-2005, 03:42 PM | #9 |
I put 71 c10 discs on my 68 and it works like a charm.
2002 S10 ZR2 for the dirt. 1968 C10 shorty for the street. She said the truck would be the end of us. I still have the truck! |
12-21-2005, 10:18 PM | #10 |
PROJECT 7DEUCE
A newer front crossmember would be the hot ticket very easy to perfoem and the parts are very easy to obtain..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-21-2005, 10:44 PM | #11 |
i swapped 71 front spndles,calipers with new rotors and pads. removed rear axles adn had them welded and redrilled for 5 lug wheels so all four are the same bolt pattern. made a big difference in stopping power. mine is a 69 panel but pickup is the same basic suspension.now i'm going to try swapping rear drums to disc.
12-21-2005, 11:00 PM | #12 |
rear drums to disk is a breeze as well.
