Old 12-23-2005, 02:59 PM   #1
Heavy-Chevy
Angry Big-Time PROB
rotors are worping on my one ton.
What all can cause this problem?
TRUCKS & Autos that run:
1972 GMC Sierra Grande 3/4ton LWB 4x4
1972 Chevrollet K/5 with a 6"Lift, 462 heads "money pit"
1988 K3500 Crew "Big Red" 4x4
PARTS OR PROJECT TRUCKS:
PARTS for sale or trade:
WANT :
1972 parts blazer/Jimmy parts truck
1967-72 Parts Chevy/GMC Truck
NEED stainless hubcap for 3/4ton GMC
Heavy-Chevy is offline   Reply With Quote
Old 12-23-2005, 03:01 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Big-Time PROB
heat can cuase it riding the brakes driving under heavy braking condidtions when it's raining sticky calipers etc
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 12-23-2005, 03:10 PM   #3
Heavy-Chevy
Re: Big-Time PROB
It is a Bendix calipers.
not riding the brakes, I think i do have heat problems.
When it is cold outside,it does not have much problems
If we are pulling it does not matter.
WANT :
Old 12-23-2005, 03:26 PM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Big-Time PROB
what kind of pads are you runnin?
Build Thread
Old 12-23-2005, 03:45 PM   #5
Heavy-Chevy
Re: Big-Time PROB
Matalic
WANT :
Old 12-23-2005, 03:53 PM   #6
torquepower
Re: Big-Time PROB
If the pedal is not coming back all the way, it will hold the brakes on a little. The pedal has to be back all the way for the ports in the MC to open for fluild to return. Sometimes the spring in the MC can weaken and the weight of the pedal will hold the brakes on some.
If your calipers are all corroded and gungy they won't slide freely, take the pads out and put them back on with the pins and try moving then back and forth, it should be real easy. Lubricate the bushings with high temp grease and clean the caliper and spindle surfaces that come in contact with emery paper.
Also, problems in the combo/prop valve can cause this.
Hope these suggestions help, It could be a number of things, I would start with just checking that everthing moves freely first.
71 GMC 3500 Longhorn 454
72 GMC 2500 Sierra 350
69 C20 Longbox fleetside 305
68 C10 Shortbox Stepside 250
94 Chevrolet K1500 Cheyenne 350
88 GMC K1500
torquepower is offline   Reply With Quote
Old 12-23-2005, 04:13 PM   #7
Heavy-Chevy
Re: Big-Time PROB
I have working on it for months.
Chevy house has looked at (said it was to old for them)
part house ( could not get a porportional valve,if it was the prob.)
Been to other shops too.
What about midas?
WANT :
Old 12-23-2005, 03:46 PM   #8
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Big-Time PROB
how long ago was the brake job done?
Build Thread
Old 12-23-2005, 05:08 PM   #9
crazyred
yeeha
crazyred's Avatar
Re: Big-Time PROB
Improper torque and tightening pattern on the lug nuts has also been known to cause this. NEVER use an impact to tighten them down. Try to uses a torque wrench to do this so that you know all the nuts are tightened evenly all the way around….. the unevenness can cause worping. Always try to tighten in three stages, 33% of total torque on all the nuts then 66% of torque on all the nuts and then do your final torque 100% of what the torque should be on the nuts. If you do this and always tighten the nut across then hub your rotors will only worpe from heat … and that’s a whole other story!
1969 GMC 910 97% rust free
2002 olds Alero
1986 New Yorker 4dr ... the new DD...My POS car... dude its got a turbo!!!
Don't drink and drive, you might spill something!!!
Daryl Kuchmak
crazyred is offline   Reply With Quote
Old 12-23-2005, 06:28 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Big-Time PROB
Definitely improper torquing of the lug nuts.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-23-2005, 07:05 PM   #11
OJOE
Crew Cut
OJOE's Avatar
Re: Big-Time PROB
one more thing that gets over looked a lot is the brake hose. the inside of the hose will seprate. fluid will pass thru when you apply brakes but when you let off,the hose will suck together and not let the pressure off the calipers. i have seen this a lot on these trucks.
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 12-23-2005, 07:51 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Big-Time PROB
More than you ever wanted to know about disc brake problems... http://www.stoptech.com/tech_info/wp...rakedisk.shtml
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-24-2005, 12:16 AM   #13
Heavy-Chevy
Talking Re: Big-Time PROB
Many thanks guys!!!!!
WANT :
