12-29-2005, 08:13 AM | #1 |
Please post picks of front/rear rollpans
I would like to see some picks of both the front and rear or any roll pans, prefferably on stepsides. Be it custom made or purchased through any vendor. Would also like to know how much of an ordeal you went through to install them. Thanks Bowtie
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" Last edited by Bowtie67; 12-29-2005 at 08:16 AM. |
12-29-2005, 09:38 AM | #2 |
Designated A-hole!
Re: Please post picks of front/rear rollpans
Putter's the man to see for rear rollpan. He made one that matches the back of the stepside fender. Really looks good. I'll see if I can find a link.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-29-2005, 10:03 AM | #3 |
More Cowbell....
Here is my roll pan. Hand made by your's truely. This is not the finished product. I can't find any pics of that (Krue took some while following me one day). Keep in mind that I when these were taken, I had not done ANY body work to the bed to make it pretty yet.
Anyway, since these photos, I have cut in 15" LED taillights (one on each side) that mount from the inside so they sit flush with the surface. The first one is with no pan, just so you can see the difference....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 12-29-2005 at 10:04 AM. |
12-29-2005, 10:08 AM | #4 |
More Cowbell....
Oh, sorry...I didn't answer the question part of the post...
The frame ends were going to touch the rollpan, so I had to trim them at an angle to make the pan fit. I only removed about two inches at the bottom of the frame rail and cut at an angle to zero inches at the top. Basically cut off a small triangle. Mounting it was simply drilling three holes on each side in the fender's lip and bolting her up. Could have been done with two bolts on each side, but I wanted it to stay put. You could also weld it on, but there was always the possibility of wanting to remove the fender later, so I bolted mine on. ***THE BOLT YOU SEE HANGING DOWN IN THE THIRD PHOTO IS FROM THE TANK STRAP...NOT THE ROLLPAN.***
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 12-29-2005 at 10:10 AM. |
12-29-2005, 11:54 AM | #5 |
I actually saw your truck in another post and that is why I had posted to see some other picks as well, yours does look like a very clean simple setup. I agree about bolting it on as well, you never know if you'll ever have to take it off to do other things later.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
12-29-2005, 12:07 PM | #6 |
More Cowbell....
I contacted Sir Michaels and offered to send them one if they would produce them for me. They never got back to me, so....at least I have something different.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
12-29-2005, 02:10 PM | #7 |
some are board members, dial up beware.
12-29-2005, 02:03 PM | #8 |
PROJECT 7DEUCE
Heres a front pan...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-29-2005, 02:11 PM | #9 |
12-29-2005, 02:12 PM | #10 |
12-29-2005, 02:19 PM | #11 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-29-2005, 05:08 PM | #12 |
Brandon- 1966 Bel Air more door 1968 C/10 Shop Truck: SWB Project coming soon 1996 Silverado Z71 Rest In Peace Mom 5/11/58-12/2/09 RIP Grandma and Grandpa Amanda Royster 9/21/87-2/5/06 Last edited by 93Z71; 12-29-2005 at 05:13 PM. |
12-29-2005, 05:51 PM | #13 |
love my truck
mine
