1972 C10 Cheyenne LWB
![]() Join Date: Dec 2005
Installing Lab-Shoulder Seatbelts from Andover
I'm having trouble installing some retracting lap shoulder seat belts from Andover (thru American Classic). They came with an L-bracket for the anchor on the retracting spool. The problem is that the anchor bolt, from the old seat belt, is right under the gas tank and I can't wedge the spool up under the cutout in the gas tank and still have the spool facing up. Any suggestions in getting the spool anchored?
Thanks! |
67-72 Addict!
Re: Installing Lab-Shoulder Seatbelts from Andover
Since it's aftermarket, you may have to drill a new hole to suit your location. That's what I do.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#3 | |
#4 | |
67-72 Addict!
After you install you can use undercoating to help seal it and keep from rusting.
The shoulder belts I installed the retractable spool goes by the door on the side of the seat. And the solid part with the buckle mounts behind the seat by gas tank.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
