Old 12-29-2005, 02:17 PM   #1
GMC70c20
Cutting coils pros cons
I was thinking baout cutting the coils on my c20. I would only lower the front about 3 or 4 inches. I dont really care about the ride or handleing of it seen's how the only track it will see is a drag strip. I was going to use probably a 15 in wheel. What are some of the pros and cons of doing this? and Does anyone have a picture of a truck setup like i'm describing?
GMC70c20 is offline   Reply With Quote
Old 12-29-2005, 05:06 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Cutting coils pros cons
I would cut 1 full ring (no more, or no less). You will get a 2 1/2-3 " drop, & will need to trim the bumpstops off the lower a arms. Leave a pc of the steer stop, & use a traction bar snubber for the new bumpstop. my longhorn was done this way, but she also runs 1/2 ton rotors/spindles & has a 1 1/2" body drop......pics http://community.webshots.com/user/hotrodhorn L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-29-2005, 05:27 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
When you cut the spring put the end that you are not cutting into a bucket of water... Heres my truck with one loop cut off..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-29-2005, 10:54 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Yeah, I wouldn't cut more than a coil or you're going to run into some camber/alignment issues that won't be able to get corrected. Also, cutting an even coil off allows the coil to be fit back into the spring pocket for correct fitment. If you wanna go lower, you need to pony up the extra bucks and get some drop spindles.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-30-2005, 12:39 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I have done it many times in the past with no negative results. I have used everything from a cutting torch with the spring in a bucket of water (already mentioned) a cut off wheel on a high speed grinder, a Sawzall, and even a hacksaw....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-30-2005, 08:29 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I also cut coils a lot, without problems.
You mentioned 15 inch wheels on your C20. I've been told that a 15 inch wheel won't clear the big brakes on a 3/4 ton, and that's why they all came with 16's.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-30-2005, 12:07 PM   #7
crazy longhorn
I am not sure how they would clear disc brakes, but my Longhorn had 15" white wagon wheels on the rear when I got her. I doubt that you will find anything in a 15" 8 lug, other than the white or chrome wagon wheels. The aluminum wheels(being thicker due to casting) would not clear the brakes for sure! L
Old 12-31-2005, 02:45 PM   #8
GMC70c20
I was looking at bfgoodrich drag radials but, they only had them in a 15in wheel. What other drag radials come in a 16in wheel?
Old 12-31-2005, 06:29 PM   #9
crazy longhorn
BFG does offer 16/17/18 drag radials, but they seem to be all low profile, & dont get over about 26-26.5" on the height. On the 15" wheels for your truck, a 15x8 usually has most of the offset on the outside.....a steel (chrome, or white) in a wagon style or modular should fit you truck(rear anyway). You can run what ever you want for "street"..... he!! go 16" ,& get some nice wheels. Go 15" on the rears, in the drag radial.The BFG's you wont want to run on the street, save em for "race day", & mount em on those cheap "ugly" wheels He!!, you will never make those BFG"s "hook" on the street anyhow(too much oil,antifreeeze ect) best of luck, L
Old 12-31-2005, 06:35 PM   #10
qksilver
Mickey T's Has some non DOT street styles in 16, not sure of the sizes though. As far as 15" 8 lug wheels, steel ones will fit I have a set but forget any type of mag wheel.
qksilver is offline   Reply With Quote
