Old 12-29-2005, 11:23 PM   #1
truckdude239
truckdude239's Avatar
another start and stall
okay been having trouble latey alot of it it seems lol. anyway i got an 1971 checy c-10 with 307 when ever i stop the truck stalls out i adjusted the idle so that it idles about 800-875 rpms sittin in the drive way it was idlein fine but the frist trip down the road it stalled out when i pushed the clutch in and started braking just sort of putt putt dead no vac leaks i fixed all them. i'm half ready to jerk the motor out and stick another one in ther just got to make it to pay day. lord help me lol thanks in advance
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-30-2005, 05:55 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: another start and stall
I swear it sounds like a vacuum leak to me, but here's a ttt for you.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-30-2005, 10:04 AM   #3
truckdude239
i'll go check again but i thought i had all the vac leaks fixed
David fuller
2000 Tahoe 5.3l 378
Old 12-30-2005, 12:38 PM   #4
krue
Designated A-hole!
krue's Avatar
Hows your fuel filter? Have you done anything to the engine before it started doing this?
www.daveramsey.com
Old 12-30-2005, 01:34 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Just in case it has a vacuum leak you can easily say yea, or nay, by putting your hand over the top of the carb, while it is running. If it smothers and dies, versus continuing to run, then you can say no to the vacuum leak theory.
Does it have an HEI? I had a problem that arose after changing my vacuum advance. Short version: the wiring inside the distributor which fed a signal to the pickup module, would break when I let off of the gas.....which caused the "breaker" plate to move a little bit, and just enough for that connection to break. R&R'd the HEI with a rebuilt and no problemo.
Member Nr. 2770
Old 12-30-2005, 01:40 PM   #6
truckdude239
got it figured out i had an small vac leak on back of the manfoild where the was an piece of 7/16 hose with an bolt in it. fixed that it still died got to figureing out that my 800 rpm idle was the cold idle so i warmerd it up adjusted the ilde again and well i ended up having to install an new return spring becuase mine wasn't returnin lol thanks for all the help
David fuller
2000 Tahoe 5.3l 378
Old 12-30-2005, 03:42 PM   #7
krue
Designated A-hole!
krue's Avatar
Glad to hear you got it going.
www.daveramsey.com
