12-30-2005, 12:04 PM | #1 |
PROJECT 7DEUCE
Rear axle breather thingies
Does anyone have the part# or replacemnt for the rear axle breather set-up .. Little plastic thing????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-30-2005, 01:49 PM | #2 |
Re: Rear axle breather thingies
what does it look like? all i had was a rubber hose about 2 feet long clogged with dirt, and i took it off and forgot where it came off, so i need to get one back on.
12-30-2005, 02:23 PM | #3 |
PROJECT 7DEUCE
Mine had a little piece of plastic in the end of the hose kinda had a little helmet type thingie on the top of it.. I f it stops raining I will get a pic of it..
12-30-2005, 03:08 PM | #4 |
i install a see-thru fuel filter on all my diff's vent tubes.it keeps dirt from getting in the diff and vents them also.
12-30-2005, 03:10 PM | #5 |
PROJECT 7DEUCE
What about water getting into them??? Fuel filters flow both directions correct???? Just wondering how well they would work on a mud truck..
12-30-2005, 03:15 PM | #6 |
Project92 SWB stepside
I used a Polished vent that I got from summit. I had to tap the rear end for a 1/8" npt. Looks great though. May be some pics in my thread below.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
12-30-2005, 03:36 PM | #7 |
PROJECT 7DEUCE
Is it the little line going into the crossmember? Any idea on what is is really for or is it really a breather???
12-30-2005, 04:45 PM | #8 |
that's a brake line, how would i connect my breather, all i have is a hole in the differential. it's not threaded either.
12-30-2005, 04:50 PM | #9 | |
WTB this ad
12-30-2005, 05:31 PM | #10 |
PROJECT 7DEUCE
tHANKS SEE-TEN
12-30-2005, 05:57 PM | #11 |
on a mud truck i would run the diff's vent hoses up in the cab!
12-30-2005, 06:03 PM | #12 |
1968 C20 Vortec Beast
You can use GM #15771000. They are about 2.50.
Ugly or not it still kicks a**! |
