Today, I was looking at wiring on the firewall. Seeing what goes to what and what I could eliminate. I found a plug on the passenger side that didn't connect to anything(pic #1). Coming from the plug there was 3 wires, blue, green, and brown with a white tracer. The green wire was cut shortly after the plug and went to nothing. I then traced the blue and brown wires back to see where they went and they went in the hole with the arrow pointing at it(pic #2). In the same loom as the blue and brown wires there was one red wire and one black wire. They both were cut on the same end as the plug and went into the firewall in the same spot as the others. The red wire went to a key-on power soure on the fuse block. The black wire, along with the blue and brown went to a relay mounted above and to the right of the fuse block(pic #3). Any ideas of what these wires are for? Thanks
-Ben
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
Re: Lets play, Name that plug!
blower motor something
member #16
![]() Join Date: Dec 1999
Trucks with TCS had a solenoid on pass side of intake manifold by carb. They were controlled with a relay,but Im not sure of the location on the trucks. I think they had a connector similar to yours. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
68 C/10
Looks like an A/C clutch plug to me
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
#5 | |
![]() Join Date: Sep 2005
not unless the truck had ac at one point in time
hmmm....Any other ideas
i asked about this not even a month ago, turns out it's an emissions thing. one or 2 go to the carb, 1 to the trans to mess with idle or something.. mine were cut, they're gonna stay cut.
