Old 01-01-2006, 05:17 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Has anyone installed twin piston calipers or braided brake lines on 67-72?
I am going to install my 2" drop spindles this spring, along with a whole new front end, ball joints, tie rod ends, idler, pitman, calipers, rotors, flex lines, etc. I am wanting to know if any or you have upgraded to a 2 or 4 piston calipers, drilled and slotted rotors, and stainless braided flex lines? What companies make such parts for our 67-72 GMC trucks? Thanks!!
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-06-2006, 06:46 PM   #2
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Has anyone installed twin piston calipers or braided brake lines on 67-72?
Sorry I can't offer any help, but I have the same question as you do. I am wanting to go with new drop spindles and switch to 5 lug. The problem is I don't know what brakes will work with say a drop spindle from early classic. I would like to run a set of Baer or Brimbo. If any one could through out some suggetion, I would be greatful. Thanks
BigShoe24 is offline   Reply With Quote
Old 01-07-2006, 12:51 AM   #3
qksilver
do a search on Dennis Brooks, he has worked out a couple of swaps using 88 stuff on the 67-72
qksilver is offline   Reply With Quote
Old 01-07-2006, 04:58 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I think I will also check out Master Power brakes and Stainless steel brakes as well.
Old 01-07-2006, 06:14 PM   #5
7T7
Regular guy
7T7's Avatar
http://www.stainlesssteelbrakes.com/
http://www.baer.com/
I have Baer on my 77. The kit came with s/s lines and 2" dropped spindles.
If you already have your dropped spindles you can send them to Baer and they will machine them to work with their brake system.
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 01-13-2006, 07:19 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
http://images.google.com/images?q=MUSKEGON+BRAKE&hl=en
They specialize in corvette brakes and twin caliper brakes
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-15-2006, 08:17 PM   #7
mrjs80
Try these guys http://www.performanceplumbing.com/BrakeFittings.html[/URL]. They sell all the fittings and line to make all your own flex lines and length you want. Good prices too. I used them to plumb all my brakes. Stainless with A.N fittings all around!
mrjs80 is offline   Reply With Quote
Old 01-16-2006, 12:57 AM   #8
BigShoe24
True Addiction
BigShoe24's Avatar
Does anyone know if there is a bit cheaper altenative, I want twin piston calipers, but don't want to spend quite that much. Can you make a single piston work as well? Thanks
Old 01-25-2006, 03:35 AM   #9
Bubba4spd
Bubba4spd's Avatar
7T7........thats about as pretty a piece of hardware as I've ever seen. I think I'd probably mount that on the wall of my office.
Bubba4spd is offline   Reply With Quote
Old 02-03-2006, 12:37 PM   #10
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
I've got the Baer set-up on my truck. They come with McGaughy's drop spindles i beleive. If I would have known you could send them a set to machine, I would have sent some 3" dropped spondles, but you live and ya learn. By the way I'm running Baer's full kit, 1/4 front lines, 5/16 rear lines, no proportioning valve, with an 88-98 chevy booster and master cylinder. Its a bit touchy, but that mofo will stop before the dime.
Bagd72Chevy is offline   Reply With Quote
