![]() Join Date: Feb 2004
Bed Measurements
I need the measurement for the tailgate opening for a 72' C-10 fleet side. I have the GMC assembly manual but there are no specs to show the clearances for the gate. I want to determine the proper width prior to final assembly and welding. I would appreciate some help in getting that measurement........txs......bossrod
Re: Bed Measurements
I would reccomend getting the gate you plan on using and align it to fit the opening in the box.There can be a fair bit of movement that could make the gate look and fit horrible if not fit before welding. Get the fit right. Then do you 2 tacks on top of the rear sill to box side.
I would perfer not to give you the measurement that way the gate fit correctly. Hope that's not a Prick thing to say...
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#3 | |
Thanks, I figured to try it that way...
