01-08-2006, 07:39 PM | #1 |
Divorced .....WITH KIDS
ignition question
About six motns ago my truck wouldn't start & a friend of my dad checked it out and told me it was the ignition cylinder. He ran a wire fromthe dist. to the battery so I could move the truck. I had to remove the wire from the battery to shut my truck off. I bought the igniton cylinder and Ithink I can install it but my question is what do I do with the wire thats connected to the dist. I don't know if there was another wire hooked there or what. I just thought I'd ask the members their opinion on the diagnosis and the wire before i paid someone to install it.
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
01-08-2006, 07:48 PM | #2 |
Re: ignition question
There should be a yellow wire that is connected to the distributor. You'll want to reconnect it....
ooppps.. you connect the yellow one if you're running hei. if you are running points...I think you connect it to the coil?? someone correct me please. |
01-08-2006, 07:57 PM | #3 |
Yellow wire goes to the + terminal on the coil (points). If there has been a HEI conversion it's hard tellin' what goes where , but there should be a plug that goes directly to the distributor.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
01-08-2006, 08:50 PM | #4 |
It was converted to HEI a few years back
01-08-2006, 09:02 PM | #5 |
Designated A-hole!
Charles, look on your fusebox, there should be a blade type terminal between the uses labelled Ign Unfused. You plug your wire from the Distributor into that. It will power the distributor with the key on and kill it with the key off. (that's the way I wired mine when I converted to HEI). I'll try to post a pic of what I mean.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" Last edited by krue; 01-08-2006 at 09:04 PM. |
01-08-2006, 09:04 PM | #6 |
There's some great information on how to wire an HEI distributor in the following thread. Scroll about 3/4 of the way down past all of the inline 6 stuff.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346 The way krue describes it will work great. That's how I have mine wired, but I really like the way it is done in Shifty's thread. It's really clean. I'm planning on rewiring mine that way eventually. Last edited by pjmoreland; 01-08-2006 at 09:06 PM. |
01-10-2006, 03:16 AM | #7 |
If he just removed the original HEI hot wire and let it drop down, it might still be there waiting to be plugged back in.
