01-13-2006, 07:47 PM | #1 |
cpp new panhard rod
I just installed this on my truck. it seems to me that should solve the problem with it hitting the frame when aired out. it was $109.00 from cpp.
01-13-2006, 08:00 PM | #2 |
Head Peon
Re: cpp new panhard rod
Any chance you've got some bigger pics...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
01-13-2006, 08:09 PM | #3 | |
01-13-2006, 08:18 PM | #4 |
mabey these will be better
01-13-2006, 11:16 PM | #5 |
nice but holy big tires batman, those 31's
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
01-13-2006, 11:50 PM | #6 | |
01-14-2006, 12:18 AM | #7 |
Outlandish Trends - FL
Looks awesome! I have a few questions though:
1. What was hitting before? The adjustable panhard only corrects the rear end from shifting over as you get the truck lower. 2. What bags are you running? 3. Since the adjustable panhard bar you have (super track bar) wraps around the trailing arm on the passenger side and is about 1/4" thick, is there something you put in between the block and the driver side trailing arm to level the rear end out? Otherwise, it would be off by 1/4" to the pass side. I have the standard adjustable panhard bar and it just uses the stock mounting location. In hindsight, I should have gotten the super track bar like you did.
-Bret 67 short-fleet sold! |
01-14-2006, 12:40 AM | #8 | |
I'm watching you!
Also does it bolt up to the stock frame location or is there a new bracket? Looks like a good project going on there!! Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
01-14-2006, 01:46 AM | #9 | |
and thanks. i am doing a frame off, so i won't be able to drive it for quite a while, but i can't wait till it's done Last edited by lvscott; 01-14-2006 at 01:46 AM. |
01-14-2006, 01:43 AM | #10 | |
2. i am running coinitec bags, 3'' DJM drop spindles, strong arms, cpp c-notch and 2'' blocks. 3. the kit comes with a plate the same thickness as the mounting plate for the opposite side. the only thing i might change is the c-notch to a step notch. without bump stops i only have about 2'' or 2 1/2'' till i bottom out at ride hight. i want it to sit level, no rake. Last edited by lvscott; 01-14-2006 at 01:48 AM. |
01-14-2006, 02:50 AM | #11 | |
That's a simple bolt on fix. My buddy, n2billet, did a similar plate but fabbed & welded his in. His pics are in the truck section & there's a decent shot of what he fabbed. I wasn't aware that a bolt-in solution was offered. Good info to know.....
