Old 01-16-2006, 05:10 PM   #1
Army_Dude
Squealing belt...
Whats the best way to diagnose which belt is squealing? I got one that is driving me nuts. They all look good. Not too loose or too tight.
Army_Dude is offline   Reply With Quote
Old 01-16-2006, 05:48 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Squealing belt...
did you check the underside and see if its glazed or anything?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-16-2006, 06:14 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Usually it is not that hard, just rev the motor at the carb and it should become obvious. If it is doing it all of the time, then get a bar of soap, the small bars from a hotel works best. As you look for the noise stick the bar up against the rotating belt and coat the inside, the squeal will go away or change tune. If you are one that has problems doing this then use a spray belt dressing to find the squeal.
Old 01-17-2006, 02:11 PM   #4
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
I have always used a Crayola crayon! If you let it touch the side of the belt or the face of it..use black so you dont have a colored belt haha. It will quieten immediately and that will tell you which belt it is.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 01-17-2006, 03:11 PM   #5
1976K5CHALET
1976K5CHALET's Avatar
If it isn't a glazed belt...and at the worst case...ensure the top of the belt is flush with the top of the pulley groove...as it should be as the pulley groove is designed for (x) series belts (15) i believe. I couldn't cure my squeel even with quality goodyear gator back belts so i bought new pulleys and it cured the issue.
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 01-17-2006, 11:10 PM   #6
jimfulco
Get out the WD-40 & give a little pop to each belt while the motor's running, and the squeaky one will quiet down.
jimfulco is offline   Reply With Quote
Old 01-18-2006, 11:12 AM   #7
hotrodhomi
hotrodhomi's Avatar
Replace them all. They are cheap.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-18-2006, 11:54 PM   #8
bmartin9122
bmartin9122's Avatar
Yup... I just replaced all three for only $40. Gates too! If you can't afford that, then you can't afford to fill-up these thirsty babies.
There is a product called belt dressing by Gunk (I think) which is an aerosol spray. It will buy you a few squeak-fee days.
79 GMC Sierra Grande K15
--PPG paint code 62608 Sunburst Orange Metallic (WA802K)
--Gentex auto-dimming rearview mirror model K31
--Carriage Works billet grille model 40071
--Go Industries 2.5" tubular stainless headache rack
--Sylvania Silverstar sealed headlights model H6024ST
--Texas Saddlebags center console model 101
--Brown's Welding class IV V-5 pipe bumper
--Ramsey RE8000 winch
--33" tires
bmartin9122 is offline   Reply With Quote
Old 01-19-2006, 07:35 AM   #9
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Squealing belt...
If your truck has the one surpintine belt look at the groovs of the crank pully mine were cloged with small chunks of rubber from the belt and it was causing it to slip and squeal i removed the pully and sand blasted it and repainted it and it stoped.
If you dont have access to a sand blaster then a wire wheel will do the job as well.
Good luck
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
