01-18-2006, 07:52 AM | #1 |
Ignition Switch Help
How do i get the ignition switch appart on my 68 if i dont have the key ? i dont want to destroy the thing just remove it.Am i going to have to break it?thanks
01-18-2006, 09:24 AM | #2 |
Re: Ignition Switch Help
When you look at it, there is a thin piece of metal that covers the end of the actual switch. If you get this off, the other piece will unscrew and come off. I drill out the center, grap the thin steel with a pair of pliers and pull it off. I've done it several times when I didn't have the key to turn it backwards and push the pin down to get it out. Of course, I then had to buy a new switch and key.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
01-18-2006, 09:51 AM | #3 |
sounds good thanks for the help
