Old 01-19-2006, 07:47 PM   #1
bigstoys
*PIMP*
bigstoys's Avatar
rear end ????? feedback asap
does it matter what time of rear suspension your rear end came out of???
here's the senario... 67 with coils wants to put a 71 rear end which had leaf springs... will it work???
http://members.cardomain.com/bigstoys
bigstoys is offline   Reply With Quote
Old 01-19-2006, 08:38 PM   #2
dwaite72lnghrn
Re: rear end ????? feedback asap
You will need to weld on the bracket for the coils, as the leaf spring brackets are different.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 01-19-2006, 09:32 PM   #3
dennislbrooks
dennislbrooks's Avatar
If you are putting the 71 in a 67, maybe you just need to compare the perches and move as necessary. This should be a possible swap. May be easier just to find a 71/72 that came from coils.
dennislbrooks is online now   Reply With Quote
Old 01-19-2006, 09:36 PM   #4
cdowns
cdowns's Avatar
i don't think the leaf rears had panhard bars so you'd have to weld bracket for that also
Old 01-19-2006, 09:50 PM   #5
Swap the internals between the housings?
Old 01-19-2006, 10:16 PM   #6
dennislbrooks
and re-use the 67 6 lug axles? --- should work
Old 01-19-2006, 10:49 PM   #7
JRB
JRB's Avatar
Why are you doing the swap and what kind of differentials are they? 12 Bolt Chevy? 10 Bolt Chevy? Are you looking to change the ratio?
JRB is offline   Reply With Quote
Old 01-19-2006, 11:10 PM   #8
If your looking at swapping internals, like axels, the 72 axle is a bit wider. I think about 3/4". But you should be able to swap out center sections if you just want the gears out of the 72.
Old 01-20-2006, 08:34 AM   #9
It`s a`71.
Old 01-20-2006, 11:13 AM   #10
bigstoys
*PIMP*
bigstoys's Avatar
the 67 has the disc brake conversion which is now 5 lug and the rear is the factory rear 6 lug. we want to buy rims and what not and it's just easier to buy all the same lug pattern ie. tire rotation, blow outs. i think the factory rear is a 10 bolt and the new rear is a 12 bolt posi with 3.73's. so we have to cut brackets off of 10 bolt and re weld on 12 bolt.... am i correct.
Old 01-20-2006, 11:14 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
71...still 3/8 inch wider.
Old 01-20-2006, 11:28 AM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
OR, you could do what I am planning on doing. I can't seem to find a good coil spring 71/72 rear-end, and I too, have a 5 lug disk brake set up on my truck with a 6 lug rear. Early Classic Enterprises sells 6 lug front rotors that will work on your truck. They are about 180 bucks for the pair plus shipping. Just a suggestion....
The rear ends I have found around here are like $250 and well used. Make sure when you cut/weld the perches that you get the angles correct on them and that they are straight and square. It sucks when you burn through a set of rear tires after only 10K miles
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-20-2006, 11:49 AM   #13
Longhorn Man
2 bills for rotors?!?!
I used to push those for them for the same reason you are bringing them up... but man, 2 hundred bucks.
Old 01-20-2006, 12:05 PM   #14
67ChevyRedneck
Andy, that's just what I've seen in their catalog, I think $89 each? If you know where I can get them cheaper I would be much appreciative. I only paid $70 for the pair of 5 lugs I got from Advance Auto.
Jesse James
Project "On a Dime"
Old 01-20-2006, 01:10 PM   #15
Longhorn Man
I know it differs from junk yard to junk yard, but around here you could get a whole rearend for less than 100 bucks... it's just a matter of waiting untill one comes through...esp if you want a particular gearing.
Have you contacted local machine shops to find out what it'd cost to have your axles redrilled?
Old 01-20-2006, 01:55 PM   #16
67ChevyRedneck
The yard's round here must have all gotten together and agreed $250 was the going rate. I went to 4 near columbia (SC) and they all wanted $200-$250. I'm not a big fan of redrilling axles. As far as rims, I'm going with a brand new set of white spokes so 5 or 6 lug won't matter.... I'm going back to Cola this weekend, might be time to check around again.....
Jesse James
Project "On a Dime"
