![]() Join Date: Dec 2004
what causes this??
well,my dad put a new holley on his truck,he messed with it alittle bit,seems to run great,but now when he shuts it off,it deisels a little,how can he fix that,any ideas,its a new holley 600 that does not have adjustable floats,its called a next generation needle/seat,just doesn't look right without that nut and screw on the top,but seems to work okay,just this little problem.....mike
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
Re: what causes this??
It sounds to me like your timing is too advanced. It could be a combination of a number of things like the timing along with the idle too high. Check your timing with a light.
#3 | |
Ill third that...
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere... -72' C10 350 Auto 12 bolt, runs 19's?? drives to work! |
Fabricate till you "puke"
Call me #4 on that! Try setting the idle speed down, & see if that helps(assuming the timing was not changed, & there was no prob before)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
its all about the +6 inches
third choice, it may be a little lean.
If timing is good, and idle speed is good, fatten up the mixture a bit. |
#7 | |
if she's lean, she'll do that...
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! ![]() |
I'm going with mixture also.
Dan
Good Judgment comes from experience. Most experience comes from bad judgment. |
Saving one 72 at a time!!
![]() Join Date: Sep 2005
Timing !! (I'm with the other guys -I guess #5)
Try retarding it a little |
Designated A-hole!
Check idle first.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
69fatmotor
good call everyone!
right on,thats what i needed to know,we never touched the timing,but will look into it.......mike
If the timing was never touched... then it should be fine... or good enough anyways.
Idle speed... it would be noticeable IMO... 850 RPM isn't going to do it, we're talking like 1000 RPM. So that leaves mixture. |
Check your idle speed first and set it to spec. And see what happens. Then check your timing just like the last few replies. Generally it will run on if your idle is to high, when its set at a higher than norm idle the throttle doesnt close enough to stop the air and fuel flow and the truck will continue to run. Make sure that your throttle linkage is set properly as well especially if you changed from a different style carb!! Just my 2bits..
#15 |
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
If you just replaced the carb. It is very likely a linkage problem. I went two barrel to quadrajet. The linkage hung up and kept the throttle from closing. It took 6 months of messing with throttle and timing adjustment before I solved it by adjusting my thottle linkage bracket.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
#16 |
Stock carb more than likely had a idle stop solenoid to close the throttle plate completely with the key off. If your holley throttle isn't closing as somebody already mentioned it will deisel with the key off.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
