![]() Join Date: Nov 2004
Weekend Progress Anyone?
I don't get to post under one of these that often, and I didn't see one started..... so here goes.
I went to advance and picked up a few things for the '67. They actually had a voltage regulator for my truck on the shelf ![]() ![]() ![]() I needed to decide to continue my quest for a new 5 lug rear end (that hasn't been going well) or replace my new 5 lug spindles with ECE 6 lugs. Pulled the cover on the rear end. Clean as a whistle and no signs of wear..... Cleaned up and painted the cover and bolts and put 'er all back together with a new seal and gear oil. Two days and she didn't drip ![]() ![]() Anyone else? ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-23-2006 at 10:16 AM. |
English Chevy Owner
Re: Weekend Progress Anyone?
Made some rust holes bigger, see my post!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#3 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Continued on the body work on the truck. I just have the cab top and right door to put in primer. Then, the fun part starts, "Block Sanding".....
Still hoping to get this in paint by "Spring".......
1997 GMC Sierra Ext 1965 Mustang |
Hot Rods For Life
Sent the truck off for paint, after I finished shaving the firewall.
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
In a quest to get my headlights to work, I dissasembled, cleaned, regreased and reassembeled my headlight switch. Worked like new. Still no lights. Traced my problem to my dimmer switch burried in cow manure on the floor. When I pulled the wires, the switch body (pot metal) crumbled, so I made a short jumper wire, and presto I have lights.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
Picked up my brackets and headers from the powder coaters , ceramic coat for the headers . Nothing like new powder coat
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
![]() Join Date: Oct 2005
Took the trash to the dump, on the way home noticed the truck filling like it was slowing down on its own, just before pulling into the driveway I put it into nuetral to let it coast and she came to a stop on her own, Parked it, jacked it up, removed the tires then the brake calipers and told my wife I was headed to advance and she told me that I should take a cot and sleep up there. She also needed the belts replaced on her car so I did that, what a PITA, Next day went and got my calipers replaced them and today I preassure washed 34 years of grease and dirt off from under the truck. Also took the kids to the circuss on saturday and was still told I wasn't spending enough time with the family.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
Never Done?
![]() Join Date: May 2000
I finished up enlarging the holes for the lower control arm u-bolts (new bolts are bigger!), then I cleaned up the brake dust shields, then got help from a friend and put the shafts in all the control arms. A few more pieces and the front end is going back together!
Went to Waco Autorama yesterday with my 2 sons. They really enjoyed the show. My youngest favorite was the motorcycle from American Chopper that they built for that skinny chick from Eddy Tx. Finally enjoyed the rain. It has been a long time since we have had any.
72 Super Cheyenne lwb 4X4 Ocra / White ![]() 88 Chevy 1 ton Dumptruck ![]() 88 Chevy 1ton Flat bed 4X4 white ![]() |
#12 | |
#13 | |
You know if you are serious about 5-lug you can order a set of axles from summit for like $200. I put 5-lug curries in a 68 3:73 posi and I love em. It is cheaper or at least close to the same $$$ and you'll then have the more common 5 on 5 rather than the 6-lug. Either way, it is up to you, I just wanted to offer my help in our quest!! I just drove my new K5 home and cleaned out the garage as well as putting the 20's on my 454SS truck. I worked all day and watched my Steelers get into the Super Bowl, so the rest was just icing on the cake!! |
#14 | |
Son Of Gravel Man
Saturday I worked as usuall.
![]() Sunday I took half my truck apart to hook up the washer bottle I got from Billsbowtie. It took me twice as long to get every thing off and back on then fixing the washer lines. It only sprays half the time so I may need a new pump. ![]() ![]() ![]() So I think I broke as much as I fixed. ![]()
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
#15 |
well it rained here and ended our blistering hot drought of a winter. we're still on a burn ban though.
#16 |
![]() ![]() Join Date: Jul 2002
Did nothing except sit and lay around waiting for this foot and eardrum to heal.
#17 |
68 C/10
This is mine: http://67-72chevytrucks.com/vboard/s...d.php?t=186987
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
#18 |
someday it will be done!
unfortunately I had to work all weekend so nada was done.
I guarantee I'll be posting some this coming weekend though ![]()
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#19 |
Finished rebuilding and adjusting the Rochester 2GV.
Took the Blazer to Firestone and had a set of 32x11.50R15 Goodyear MT/Rs installed. Swapped clogged 2-row radiator for 4-row, zip-tied into place while I await brackets from LMC. Drove the Blazer more than 100 miles. That's 5x as far as I have ever driven it. I *almost* trust it.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
#20 |
I spent all weekend at Barret-Jackson Auction watching people spend ungodly amounts of money on cars.
#21 |
Pics of my new tires:
#22 |
I got my 67 c10 running and drove it home from my folks. Still needs a little timing work, but I'll get her.
#23 |
outta the car velocityboy
Stripped the whole interior, carpets, seat, dash bits, cluster, steering column the works, out of the 72. Gas tank to come out and she's ready for the cab lift off. Have pics, will post when i get my software sorted out to update website..
Cheers Lee
