Old 01-23-2006, 01:57 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Slip on cab supports???
What exactly is the advantage of the slip on versus the regular? Has anybody tried these?. Mine are rotted and and I want the easiest ones I can get.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 01-23-2006, 02:01 PM   #2
mrein3
mrein3's Avatar
Re: Slip on cab supports???
Run don't walk away from that idea. All the slip-ons do is cover up the problem. The ONLY way to fix these is to buy the non-slip on ones, cut the old ones out, and weld in the new.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-23-2006, 02:08 PM   #3
northcountry67
northcountry67's Avatar
I agree 100%. The only way to stop rust is to remove it. Take the extra time and do it right.
northcountry67 is offline   Reply With Quote
Old 01-23-2006, 02:10 PM   #4
c10crazy
Like a Rock!
c10crazy's Avatar
I thought they still had to be "welded" on to the cab.
69 LWB
Old 01-23-2006, 02:13 PM   #5
northcountry67
Very possible, but If you only cover the existing rust you will be repairing it again down the road.
Old 01-23-2006, 02:25 PM   #6
c10crazy
Like a Rock!
c10crazy's Avatar
Thanks for the help.
69 LWB
Old 01-23-2006, 05:12 PM   #7
matthufham
i cut the rusted part out of my truck and left it. now there's a huge drain for anything that gets in the cab supports.
i don't suggest you do the same but i'm poor and don't care.
matthufham is offline   Reply With Quote
Old 01-23-2006, 05:23 PM   #8
jamis
F.A.S.T. president
jamis's Avatar
the slip on ones are ok as long as the rust damage is not structual hazard. The rear slip on ones arent even close to the correct shape the front are pretty close. But like others have said, it is only a cosmetic cover.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 01-23-2006, 11:35 PM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
Ok . Can you still buy GM?? I have never seen them on ebay. Any other places. Are they expensive and do you have to remove/lift the cab
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-24-2006, 10:13 AM   #10
jamis
F.A.S.T. president
jamis's Avatar
You can buy them from any one of the wonderful venders here. I use Mothertruckers. They are reasonably priced. Yes you do have to remove the cab to do it right, lifting the cab up is not enough unless your just going to "slip" it in place to cover up a rust hole. But I still dont recomend the slip on ones.
Old 01-24-2006, 02:03 PM   #11
mrein3
mrein3's Avatar
I bought a full set of non-slip on ones from GMC Paul's. Thus far I've only installed the RF one. I for sure did NOT remove the cab from the frame. I did the work when I had the RHS rocker off. I believe I only removed the cab mount bolt that goes through that support. I loosened the other three and gently lifted the cab up a tad with a block of wood on a floor jack.
'72 Malibu hard top
Center City, MN
