Old 01-24-2006, 07:06 PM   #1
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Steering Column teardown questions
I want to switch out the shaft from the original coulumn into the van one is this possible ? How do I get the shaft assembly out. I am doing the steering mod because of the bodydrop and the angles are too extreme. Thanks
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 01-25-2006, 02:50 AM   #2
pjmoreland
pjmoreland's Avatar
Re: Steering Column teardown questions
Are they both tilt columns?
pjmoreland is offline   Reply With Quote
Old 01-25-2006, 03:44 AM   #3
camaro__thunder
Just the van is tilt, the other is not. If I cant swap them I will cut the van's shaft down and reweld the splined part farther up.
My Project 69 SWB
Old 01-25-2006, 09:37 AM   #4
72MARIO
72MARIO's Avatar
Your best to shorten the shaft that attaches to the steering box. And the van shaft is diffirent than the truck so they will not interchange.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-26-2006, 12:32 AM   #5
camaro__thunder
It is on the steering box as far as possible (just the spline that sticks out)... Well I guess its off to cutting and welding !
My Project 69 SWB
Old 01-26-2006, 12:50 AM   #6
72MARIO
72MARIO's Avatar
You drill out the plastic rivits and hammer out the inner shaft. The cut off 2" from the inner shaft. smack it back together and add the U joints wherever you need them.
2005 TAHOE DD
Old 01-26-2006, 10:21 PM   #7
camaro__thunder
My setup looks like this and the problem is the shaft coming out of the column is too far down.
My Project 69 SWB
