01-27-2006, 12:03 AM | #1 |
Radiator Selection
I've been browsing through some catalogues and I have a question about radiators.
I understand that factory radiators were selected based on the cooling needs of the particular engine in the truck. I also understand that many had autotrans coolers built in. But what difference does it make if a truck had air or not? Asked another way, what is the difference between a 4 row rad w. trans cooler in an AC truck vs. a non AC truck? Just wondering.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
01-27-2006, 08:10 AM | #2 |
Re: Radiator Selection
Generally 4 core radiators where used behind high performance motors, big blocks and the 400 small blocks. In most cases when you have AC your engine is under more of a load and during the hot somer days and being stuck in traffic the larger radiators worked a little better to keep things cooler. I am not 100% positive here but a 3 core radiator behind a 350 with AC is basically the stock option, the 4 core option with the 350 with AC may have been more in line with a towing package.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
01-27-2006, 08:48 AM | #3 |
Active Member
I bought a 4-row from http://www.radiatorbarn.com/ for my 72 SWB 4x4. (You need to get teh 4-row brackets and rubber from someone like LMC or Brothers), but you can ge a 4-row with automatic cooler for $184.00 with free shipping from them. They are not refurbs, they are brand new. Mine keeps my 350 nice and cool. I am going to buy another for the 69 Blazer I am currently restoring. I think it's a great price and they have great customer service.
JC |
01-27-2006, 02:54 PM | #4 |
nothing wrong with putting in 4-core radiators, but for a 350, might be overkill. Check out www.usradiator.com, the sell a hi-efficiency 3-core that will fit in place of 2/3 core radiators using the same brackets/rubbers. No need to modify the lower core support.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
01-27-2006, 04:13 PM | #5 |
That AC trucks need additional cooling is a given. I guess I was wondering if the AC rads had different brackets or something to allow for AC installation.
Is it just the 4 row rads that need new brackets and rubbers?
01-27-2006, 08:07 PM | #6 |
Active Member
Yes they do have to have different upper and lower brackets and rubber inserts, plus you do need to modify the lower core support (I had forgotten that). It's not a big mod, you just need to notch the lower core support lip the width of the bracket to allow it to sit flush with the core support lower section. The cut is easy, I just used a dremel tool (didn't feel like hooking up my compressor and using my cutoff tool). It was easy to do really. To give you some idea of the cooling change, the guy I bought the truck from had a std 3 core in and when he towed he overheated. His solution was an engine oil cooler...now it not only runs dead cool while towing but it no longer needs the oil cooler.
JC |
01-28-2006, 12:10 AM | #7 |
I went scrounging at a local junk yard and found a 74/75 Olds wagen with a 4 pass cross flow radiator. I had to move the bottom tank supports over a couple inches but the tops were right on the money. My 69 was originally a 6 cyclinder so maybe thats why. The inlet and outlet location and size where perfect.I really don't think theres any difference being for a/c or non a/c other than maybe an extra pass or core. My 2 cents, Hey your in Manitoba,you shouldnt have to worry bout a/c or overhaeting.....
01-29-2006, 02:32 PM | #8 |
Your're right, Manitoba summer temperatures aren't a big concern for vehicle overheating. My question was a bit academic, but...
Right now my truck has an L6/3 speed with the dinky little rad that came with that combination. In Spring I was driving at about 70 MPH for a few miles and the temp light came on. Other people with this combo have also said that the 3 speed causes the engine to rev so high at highway speeds that the thing runs hot. Maybe a 4 row is overkill, but if my little L6 runs hot, I can imagine that some of my 400 hp SB dreams will need some careful rad selection.
01-29-2006, 03:02 PM | #9 |
ALMOST ALL OF THE TRUCKS I'VE WORKED ON OUT HERE IN THE HIGH DESERT ARE FOUR ROW RADIATORS. MAYBE IT'S A OUT WEST, REGIONAL THING. SOME CHEVY VANS ( ALOT OUT HERE) OUT OF THE 70s & 80s CAME WITH FOUR CORE RADIATORS , AND THE BRACKETS ARE THE SAME AS IN OUR TRUCKS. THEY ARE VERY VERY PLENTIFUL. I HAVE NEVER CONSIDERED GOING ANY SMALLER. I HATE OVERHEATING. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-30-2006, 12:45 AM | #10 |
someday it will be done!
I picked up a Griffon 4 core aluminum rad to put in front of the 400sb that'll be in my truck.It's not as purty as some,but the price was way more reasonable than the polished up ones and I've heard alot of good things about them.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
