What else on a 79 van will work?
I got the tilt out, but I'm curious as to what else I can use off of this van. For instance, cruise control? What about the cruise from a 85 truck? The guy is going to be be hauling these vehicles to the scrap yard and I want to get anything that can be used on my 71 off before hand.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
![]() Join Date: Aug 2001
Re: What else on a 79 van will work?
Hmmmm.... The Inside Window Cranks, Door Handles, Remote Door Latches, Sidemarkers , Fan Shrouds & Hei Distributers Come To Mind. The Fan Shrouds Are About Twice As Thick As The Oem Ones On Our Trucks & I Prefer Them Myself.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
anyone tried a van fuel tank?
common sense isn't so common anymore |
Will any brake or front suspension parts work? Rear axle?
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
I used a van for lots of parts. Mine was a 77( I think ). shroud didn't work, but the rad did, I also used the motor & tranny, power steering pump & alternator and all brakets. The door key lock things worked ( with a van you have 3 ) didn't bother with brake or suspension parts . But I did save teh cruise stuff, still in a box. Side marker lights look the same as on trucks. I saved the fuel tank, and the filler door and all the parts. I just cut the works out of the side of the van with a sawzall, later I'll see about using the door for my fleetside, The tank looked a little wide, but haven't tried with the bed off so not sure. I like the inside part of the filler thing I think it will be nice inside the box of the truck. The van I had was pretty ugly and was told I had 48 hrs to get it out of the yard ( women?) So I didn't have time to check out everything.
I got a bench seat baby, you don't have to sit over there. |
![]() ![]() Join Date: Jan 2005
You could install the cruise control. I installed a mixture of cruise control parts from a van and an early '80s Caprice on my truck, but I don't see any reason why you couldn't use all the cruise control parts from the van.
http://67-72chevytrucks.com/vboard/s...d.php?t=151318 |
#8 | |
if it's got seats like this you could take them to an upholstery shop with picture of original 71-72 buckets and have lo-cost factory looking buckets you just have to cut down the van pedistals to fit the pickup//about $250 compared to the $1000 most people are paying
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-12-2006 at 08:06 AM. |
I thought about the seats, but they are some funky looking high backs with gold tuck and roll on swivel peds. No foam left on the bottoms of either one.
I read the awesome post by PJ and I have a question. I believe I got everything but the brake light switch from the van and the "solenoid that opens the carburetor slightly when coasting down the road". I don't remember seeing a solenoid on the carb that would open it up. I did get the vacuum interupt switch that is activated by the brake pedal. I guess I need to go back and get the brake switch and look for the solenoid mentioned?
You shouldn't need a solenoid for the carburetor. That sounds like some kind of emissions device.
I have seen vacuum kill switches that also have an electrical switch built into it. Is that how yours is? If so, I don't think you will need the brake light switch out of the van. If the vacuum kill switch only has a vacuum hose connected to it, then you will need the brake light switch from the van. I noticed you have a 200R4 in your truck. Do you have the torque converter clutch wired up? If so, you might want to track down a vacuum kill switch from an early '80s vehicle with cruise and a torque converter clutch. The vacuum kill switch will have an extra electrical switch you can use for providing power to your torque converter clutch. Last edited by pjmoreland; 02-01-2006 at 04:55 PM. |
#13 | |
![]() ![]() I'll swing back out there tomorrow and pull the switch out when I get the rest of the brackets I need off of the 85. Maybe I can find a serpentine belt set up out there somewhere ![]()
Oops, sorry about the 200R4 comment. I read that off of the bottom of cdowns' post by accident. Sounds like a TH400 will suit you well. After seeing how MARIO's 700R4 literally exploded on him, I'm rethinking my 700R4.
#15 |
I would like to put a 700R4 in my son's 84 for mileage reasons. But, as it stands, the motor I am going to put in my 71 with be a 69 350, bored .030, double hump heads w/64cc chambers (may have the valve size expanded, haven't actually seen them yet), 9.5-10.1.1 compression, Performer intake and a cam somewhere in the range of .282 adv dur with roller rockers. I will build the trans myself and upgrade everything I can and add a shift kit and around a 2500-3000 stall.
