Old 01-30-2006, 06:38 PM   #1
bighead
? about rear end brake lines
I've just swapped out the old 6 lug coil rear in my 67 1/2 ton for a 5 lug coil rear. On the old rear the two brake lines came from the backing plates and met at a brass block which passed through a tab on top of the axle tube. The new rear end has a horseshoe shaped tab welded to the front of the axle tube. My old brake lines don't seem like they will work. Does anybody know what year this might be? Do the brake lines still meet at a brass block? How does it attach to the horseshoe shaped tab? thanks, bighead
bighead is offline   Reply With Quote
Old 02-04-2006, 03:02 AM   #2
tom71
what happened to flint mi
tom71's Avatar
Re: ? about rear end brake lines
mine is a seventy one and it sounds like the one you described there is a threaded hole on the tab and a bolt goes thru a rubber brake hose with a brass fitting on the end
tom71 is offline   Reply With Quote
Old 02-04-2006, 11:31 AM   #3
bighead
Thanks for the reply Tom. I ended up fabbing a tab like the one on the 67 rearend and welding it in place. That way I was able to use all my brake lines and such.
Old 02-04-2006, 12:56 PM   #4
smbrouss70
smbrouss70's Avatar
were your lines long enough? I seem to remember the 69 and earlier rear-ends being shorter than the 5-lugs.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-04-2006, 03:58 PM   #5
bighead
Yep, they have some generous bends around the perches, etc. Pulled just a little slack out of them and they were fine
Old 02-04-2006, 03:59 PM   #6
smbrouss70
smbrouss70's Avatar
good to know, thanks
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 02-05-2006, 12:12 AM   #7
dennislbrooks
dennislbrooks's Avatar
keep me in mind if you get rid of the 6 lug coil--I am mainly after the axles---was it a positrac of sorts?
dennislbrooks is offline   Reply With Quote
