TrailMaster 3" drop spindles help!! please
Let the problems start again. Well I finally got settled in the new house and starting working on big red again. But ran in to some problems firs I was cheep and bought those TrailMaster 3” drop spindles off Ebay some time ago and finally got around to putting the 73+ tie rods in well they won’t fit?? The hole in the spindle is too small?? Is any one else running these? The second problem is I got those adjuster sleeves from cpp from a board member well the side that goes to the 73+ tie rod threads fine but the one to the old inter one will not thread??
Atom (bigRed66) 1966- C10 1995- Wide Body Talon 1987- Dodge Raider (4 sale) 2000- 4-door Nissan Frontier 2003- Ford Focus (wife) Last edited by bigred66; 01-31-2006 at 09:28 PM. |
Re: TrailMaster 3" spindles
I am using the CPP sleve. I used a 67-70 outer tie rods as a inners and I used 73 outer as outers. Depending on the center link you have the 67-70 outers used as inners could be too small for the center link. Mabye you need 71-72 outers to fit the spindle ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Is your truck the on on sucide doors web page ?
I went to the parts store today and looked at the "right centerline" some one over the years has swapped something on me!! fun fun LOL I got the right ones no to see if the fit to the centerline as for my spindles it is so close I think I am going to just drill it out a bit and .....yes the 66 is on SD web site the yellow wide body is also mine
Atom (bigRed66) 1966- C10 1995- Wide Body Talon 1987- Dodge Raider (4 sale) 2000- 4-door Nissan Frontier 2003- Ford Focus (wife) |
its just $$$$$
I have those same spindles. I had no peoblems with mine. Everything went together just fine.
what year tie rod ends did you use???
its just $$$$$
I used the 73-87 outer tie rod ends and stock 72 inners.
what happened to flint mi
i didnt know they made 3 inch drop spindles for a 67 72 truck where did you guys pick them up at ?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Tom , I think the Trailmaster spindles they are using are 73+ fitment.
But, Belltech now makes a 3 inch drop spindle for 71-72 trucks. It's a straight bolt on with no changing of ball joints or tie rod ends. Summit has them in stock.
Hey bigred,
If you drill your spindles out be careful (of course) but they do make tapered drill bits for just the job. I am not sure what they would cost, but you lock your spindles up in a vise and slowly open those holes up. Doing it this way will keep the hole tapered instead of straight through. Keith Last edited by a squarecan; 02-13-2006 at 11:16 AM. |
hey thanks tx i ll look into that when i get some more cash .
close I just used a round file lightly and they slid right in. As for my tie rods I am pretty sure some one flipped them on me over the years that’s why they would not thread right. Either way I got it all back together once I bought the new inter tie rod ends (they needed replaced any way). But now its to d*** cold to work on it. Thanks
Active Member
I think Im the one who sold you the adapters...? I'm glad they worked for you. I wasn't wrong in my description & application was I?
Yes you were the one who sold them to me. Thanks again! I don’t think so I just had some wrong parts on the truck LOL. They worked fine thanks. I got them in just in time for it to get colder than a well diggers ass. So I haven’t got to play with it much yet. Thanks
