Old 02-07-2006, 09:46 PM   #1
Greubin
Greubin's Avatar
1971 c20 oil pan removal - how?
My chilton manual states that the engine mount bolts must be removed and engine jacked in order to remove the oil pan, is this true? Any shortcuts? I wanna check for sludge, and clean the oil pump pickup.
TIA
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
Old 02-07-2006, 09:57 PM   #2
cdowns
cdowns's Avatar
Re: 1971 c20 oil pan removal - how?
i've always unbolted the towers from the frame lifted the engine enough to get a 2X4 block under the tower and unbolted the pan// lifes alot easier if you use a 1/4" drive rachet with a 6-9"extension to remove the bolts also get the felpro 1piece gasket set makes putting the pan back alot easier too cause they include these plastic stud things to hang the pan for installation
Old 02-07-2006, 10:11 PM   #3
Greubin
Greubin's Avatar
Cool thanks for the tip
___________
Greubin
