02-07-2006, 11:02 PM | #1 |
no more prop rod !
Well, finally got all the angles figured out on the gas struts for my hood, and got rid of that ugly wooden prop rod I was using. After the purchase of the hinges and struts, it took about $15.00 and 6 drilled holes to finish the installation.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
02-07-2006, 11:20 PM | #2 |
18 Till I Die
Re: no more prop rod !
That is SOOOOO NICE
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
02-07-2006, 11:20 PM | #3 |
I'm watching you!
Thats a beautiful truck!!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold |
02-08-2006, 12:31 AM | #4 |
Spectacular color combination. A truck to be proud of.
02-08-2006, 01:13 AM | #5 |
Just A Tool Hand
Those hinges are so nice !!!!! And the truck looks good. Glad to see that the shocks worked out for you!!
:hit: Last edited by taylorde; 02-08-2006 at 01:15 AM. |
02-08-2006, 02:16 AM | #6 |
Professional Grade
That engine makes me smile
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
02-08-2006, 05:31 AM | #7 |
Epoxy Primer Friendly
So nobody asked yet...whats the part number/where did the shocks come from ? Thank You Sir!
02-08-2006, 08:08 AM | #8 |
67-72 Addict!
We need more pics!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-08-2006, 08:52 AM | #9 | |
02-08-2006, 09:44 AM | #10 |
68 C/10
Man that thing sure is sweet!!!!!
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
02-08-2006, 10:49 AM | #11 |
I feel sorry for the other people you will be competeing against when you start showing that burb.
02-08-2006, 10:47 AM | #12 |
Jamie Hyneman is my twin
That is SWEET. We do need to see more pics, this truck is so slick.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
02-08-2006, 11:09 AM | #13 |
Sold! 2 days after finished
How did you mount the hinges to the hood. Did you weld a piece to the hood and bolt through the sasche's into that. Any help would be great.
02-08-2006, 02:04 PM | #14 |
For those who wanted more pics, here's a thread I started the day I got it home from the body shop.
http://67-72chevytrucks.com/vboard/s...d.php?t=183389
02-08-2006, 05:51 PM | #15 |
Outlandish Trends - FL
That rig makes me happy in the pants. You've truly got a masterpiece. I'd have been pretty scared to start drilling those holes in it. Did you use masking tape so the bit didn't walk on you?
-Bret 67 short-fleet sold! |
02-08-2006, 09:32 PM | #16 |
PROJECT 7DEUCE
Can we get some measurements of the shock location???? That is a sweet azz set-up seems like the hinges would have come with them struts????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-08-2006, 09:45 PM | #17 |
Really awesome paint and the hinges/struts make it very unique.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
