pulling a trailer with coil spring rear end
Hey, i'm getting ready to set up the '67 i bought a while back to be a 2-horse trailer pull queen. i don't know much about the coils spring rear ends, so i stick with leafs & 4X4's...
Anyway, is this going to be an OK truck (coil spring rear end) to pull the trailer (~2K empty)? if not, what do i need to be careful of, or add to make it an OK thing to do? |
![]() Join Date: Mar 2000
Re: pulling a trailer with coil spring rear end
A 1/2 ton will pull 5000 pounds fairly well. I pull as much as 9000 short distances with no problems. A 3/4 ton with coils and apropriate gearing/engine combo could probably handle quite a bit.
Saskatoon, Saskatchewan Canada |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You should have about 10 percent of the trailer's weight as tongue weight. That would mean you'll have about 200 pouns tongue weight. It would be about like me standing on the rear bumper.
#4 | |
The LuvShack Garage
So you're really going to be pulling some serious Horse Power ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
saving one more
I have a 72 with rear coils, I pull a twenty foot fiberglass boat & trailer, not sure how much it weighs. I put one in lowering front coils, three inch lowering rear coils, front & rear sway bars with polyurethane bushings, an adjustable track bar with poly bushings, a quick ratio steering box. The truck drives straight and I don't have any issues with towing the boat long distance (over an hour one way) up & down hills and around curves. Everything tracks straight, the only issue I have is with the boat and trailer hitched up and a full bed of camping equipment, I ride on the factory bump stops on the rear.
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
![]() Join Date: Nov 2005
I had a 68 c20 on coils all around and used it with a slide in camper . It was fine , and we loaded the %&*# out of it .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
1969K10, check your PM's.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
Got Horsepower?
i have pulled about 14,000 pounds with my C10 coil spring no problem. yeah the back end was a little low probably about 1500 pound tongue weight but my motor had no problem getting it moving. i had a 2 horse slant trailer loaded about 6,000 lbs and still beat every ricer who wanted to race. (DISCLAIMER: even though it is possible i do not recomend attempting any of the previously stated
![]() I think i need to upgrade to a 1 ton diesel
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
Young truck fanatic
You could look into some stock height HD coils or 3/4 ton springs and some stock style helper springs. I am positive that you would be able to pull your trailer....I have seen 3/4 tons springs and stock helpers springs used on a 2wd pulling truck very very successfully..
-Jake
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project. **Proud to be Valley Trash** |
Thanks for all the replies! I wasn't concerned about the motor/tranny combo, just the coil rear end... Y'all have eliminated my fears, thanks for the input!
Since it has heated and compressed springs all the way around, they'll be getting replaced. i've got new fronts from my old '72 (that never got installed before it was wrecked), that i plan on re-using. guess i'll get 3/4T coils to replace the springs in the rear... Last edited by 1969K10; 02-10-2006 at 10:14 AM. |
I used a`70 C/10 with a Reading steel utility cap&ladder rack on the bed and filled it with tools:in the side boxes,in the bed,and on the racks.The original old stock coils let the rear drop`n`sway a bit.I installed 3/4t coils and AirLift bags inside them.I could air-up when needed.
Old Skool Club
![]() Join Date: Jun 2001
My SWB 1/2-ton had (from the factory) a set of 2000-lb coil springs. The P.O. pulled a 26-ft travel trailer with it, using a 2-inch hitch receiver. Said it did way better than the 98 Silverado he replaced it with.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
