Old 02-16-2006, 01:15 AM   #1
DruBlazer
Got Blazer?
DruBlazer's Avatar
Somebody stop me!
Hey guys,
It's been a while since I've been on. My 71 4wd isn't stopping very well. I had to make an emergency stop the other day and I realized I couldn't even lock em up. Might I have a bad booster? Any ideas?
Thanks in advance,
Drew
DruBlazer is offline   Reply With Quote
Old 02-16-2006, 01:47 AM   #2
jhow66
jhow66's Avatar
Re: Somebody stop me!
How must pressure do you have to apply in a normal stop?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-16-2006, 08:21 AM   #3
How much fade on the pedal?Right away,only when hit hard,after pressure applied for awhile?
Old 02-16-2006, 08:58 AM   #4
vtblazer
vtblazer's Avatar
One very common upgrade is to swap to 3/4 ton master/booster.
What size tires are you running?
vtblazer is offline   Reply With Quote
Old 02-16-2006, 09:12 AM   #5
jbon64
jbon64's Avatar
the best way to check a booster : with your truck off , apply pressure to the brake pedal , start the motor , if the pedal moves down , the booster is good.
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 02-16-2006, 10:36 AM   #6
Jason915
71-72 1/2 ton trucks and K5's brakes suck in my opinion. My GMC is the same way in panic situations, and for towing they are very underpowered and fade out easy. I have replaced everything in my braking system and have achieved nothing as far as better performing brakes. I will be getting a ¾ ton power brake booster for both my K1500 and my Blazer that is the way to go. If you noticed that GM addressed the problem with the 73 ½ ton’s and K5’s they went to a larger dual diaphragm power brake booster and wider brake shoes in the rear otherwise they are basically the same braking system but stop much better. The 67-70 ½ ton trucks used drum front brakes and the power brake booster was adequate for a 4 drum braking system but in 71 they changed to disc brakes and still used the old power brake booster and that is why they suck. When I drive my Dad’s 70 K20 I just about put myself through the windshield the first time I tap on the brakes, and that is what makes me realize how bad mine really are.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 02-16-2006, 04:49 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Scares me just reading it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-16-2006, 05:54 PM   #8
Medicanman71
Medicanman71's Avatar
Luvy u havent mobbed yours around enuff to have any "emergency stop" situations, huh?
or have you just gone out and gotten on the brakes as hard as possible to find out how yours stops?
Medicanman71 is offline   Reply With Quote
Old 02-16-2006, 06:00 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mine is 100% new parts, pads, rotors, drums, shoes, lines, m/c,
booster, ppv, fluid, everything and it doesn't stop very well
Old 02-16-2006, 08:10 PM   #10
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Meybe yours only need a good bleeding?
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 02-16-2006, 08:17 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Oooooops, I forgot, we gravity bled it, power bled it, bench bled the mc,
and I still got squishy brakes, I think my 4wd needs the 3/4 ton upgrade
Old 02-16-2006, 09:33 PM   #12
DruBlazer
Got Blazer?
DruBlazer's Avatar
I'm running 33's on a 4" lift. During normal driving situations it seems to be adequate. The pedal seems a little stiff. I've bled a couple of times thinking "this time I'll get it". So I don't think that's the problem. I just want to make sure that, before I upgrade, there isn't anything else I could do.
And speaking of upgrade; has anyone done a rear disc conversion kit with e-brake that they'd be willing to recommend?
Thanks for the input.
Drew
Old 02-24-2006, 10:12 PM   #13
ian villeza
Active Member
ian villeza's Avatar
Just wondering if you adjusted the pads properly before bleeding the brakes? My 72 blazer brakes great and locks em up.
ian villeza is offline   Reply With Quote
Old 02-16-2006, 10:07 PM   #14
ClassicStyle
ClassicStyle's Avatar
mines exactly the same, i got new everything also. looking into doing a 3/4ton system now its scary driving on the freeway when everyone stop's and your left hoping your truck stops..
-Cameron
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 02-24-2006, 09:18 AM   #15
Huck
Huck's Avatar
Similar crappy braking with my blazer. Just swapped to a 3/4 ton booster--same problem. The only thing I haven't replaced is the calipers which will be next. Given that 70-80% of the braking comes from the front and I can lock up the right rear, I'm hoping this is the problem. What a PITA though!!
Huck is offline   Reply With Quote
Old 02-24-2006, 09:28 AM   #16
ClassicStyle
im gonna try steel braided lines and a correct brake job, somthing tells me the PO just slapped pads on a glazed over rotor.
-Cameron
Old 02-24-2006, 09:45 AM   #17
vtblazer
vtblazer's Avatar
Originally Posted by ClassicStyle
im gonna try steel braided lines-Cameron
I bet that would make a world of difference.
Now that you mention it, my one ton has those as well.
Old 02-24-2006, 02:25 PM   #18
ClassicStyle
yea i figured it would be a good mod regardless if i stayed with 1/2 ton brakes or went to a 3/4 ton setup. never know, they just might fix the problem.
Old 02-24-2006, 11:11 PM   #19
70blazerpickup
ya must be nice. im not messing around. im getting the hydrobust setup from a 73 style one ton. that will solve my breaking problems. my dads 83 one ton stops better than most new trucks.
70 blazer/pickup 104" wheelbace
70blazerpickup is offline   Reply With Quote
Old 02-26-2006, 01:38 PM   #20
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
Just curious.......does the 3/4 ton setup just bolt on to the Blazer? Sounds like a no brainer if it does.
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
