Old 02-18-2006, 12:53 AM   #1
cstanley
cstanley's Avatar
salvaged brake fluid reserviors. what's everyone using?
which ones seem to work best, the plastic ones, i mean. i've seen them on several trucks, and they look so clean. not like my crusty, rusty, leaky one. what did they come out of?
did you have to use the entire m/c booster from the donor, or did it attach right to the factory power booster?
cstanley is offline   Reply With Quote
Old 02-18-2006, 01:00 AM   #2
72MARIO
72MARIO's Avatar
Re: salvaged brake fluid reserviors. what's everyone using?
For manual brakes the 84 master will bolt right to the firewall with a little dremmel work to make the main hole a little bigger.
Not sure on the power setups. I am running a stock master painted red to match my fire wall and silicone fluid so that the paint does not get eaten.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
