02-19-2006, 10:26 PM | #1 |
Junior Member
Installing a 5 speed
Hello everyone, I'm looking for pros & cons on installing a 91 1/2 ton 5 speed into my 67 1/2 ton. I'm putting a 400smblk with dart pro 1 heads and a few perf. parts in the truck and don't really know how much abuse the trans. might take. It's a nv3500 and don't know it's torque rating. I know everything will bolt in and I'll need a 400 flywheel but was unsure about cutting a hole in the floor (new carpet) and the trans not holding up. Any info would be appreciated
02-19-2006, 10:53 PM | #2 |
Re: Installing a 5 speed
You might PM Huck. He has a 5 speed in one of his trucks. He should be able to let you know what problesm and all there is with the swap.
02-19-2006, 11:06 PM | #3 |
its all about the +6 inches
Does the NV3500 have an integral bellhousing? If so, you'll have to fab up a hyd master cylinder and all that jazz. Huck did his that way, and it worked good. his clutch pedal felt a little funny, but only took 2 or 3 shifts to get it down and be able to drive with out looking like an idiot.
He had a stock crate (260 horse?) 350 in his, but he did do some seriouse hauling too though. |
02-20-2006, 10:13 AM | #4 |
My converstion was with an aluminum based 5speed out of a 96 truck. Don't know the model but it held up well for all applications I had. Only drawback with the hyd clutch was not as soft a pedal as it should have been and the newer transmissions are not setup for gear driven speedo cables. You can get a Richmond 5 speed that will do whatever you want to do with it but it is a pricy solution. My cost me about $1,000. to do total and I enjoyed it totally.
02-21-2006, 01:29 AM | #5 |
Junior Member
I have everything for the install except figuring out how to make the speedometer work. I'm replacing the bearings now and decided to replace the syncronizers . I have a 700r4 and a 350 turbo, guess it would be easier to use one of them. Just bought a 68 and could use the 5 spd. with my tpi engine in it one of these days. Thanks for info.
02-21-2006, 11:33 AM | #6 |
chuck1960, you have a pm
thanks, chevybill
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
02-21-2006, 02:21 PM | #7 |
It'll never live behind that 400 unless you're really really nice to it.
I've had 2 in my S-10, and now I'm back to a 700r4... BTW, I have the complete setup I just took out of my S-10. If you need any parts LMK. Trans has a broken shift fork or somthin.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
02-21-2006, 10:59 PM | #8 |
Junior Member
I was planing on some street and strip use and was'nt sure about the torque rating, sooo I guess I'll just stick with a turbo350. Was just thinking I would have an adjustable stall with the 5 speed. I found out it's a lot easier to build a 350th than it has been to rebuild this particular straight shift and it will probably stand more abuse to. At least the ones I've run in the past have.
02-21-2006, 11:34 PM | #9 |
Mine made about a dozen passes down an 1/8th mile track in my severely traction limited S-10. (Non posi 3.08 daily driver.)
Best MPH 76.07 Best ET 9.941 Last pass (1st gear only and coasted the rest of the way) MPH 31.17! ET 16.792!
