02-26-2006, 12:51 AM | #1 |
help with differences in 67-72 pickups
I am having a discussion with a friend, and he does not believe me about the differences. I looked through FAQ, and did not find a post on what the differences were, so I figured I would come to the experts
and hope you guys had a link to the differences. Thanks guys/gals
Always looking for a 2wd blazer |
02-26-2006, 01:09 AM | #2 |
Re: help with differences in 67-72 pickups
67s have a different kicks and bends in the frame especialy the fround frame horns. the 68,69, 70 i bileive are the same exept for the nose. 71, 72 the trucks got the open nucle front end that is almost identical to the 73 and up exept that it is narrower. hope this helps.
70 blazer/pickup 104" wheelbace |
02-26-2006, 02:48 AM | #3 |
Here are the most obvious visual differences:
67-no sidemarkers, 45-degree slant to front of hood, plain double-slit steel grille, small rear window (large Panoramic window was an option), lower bodyline trim that follows the wheel arches, 6-lug wheels. 68-sidemarkers added, no more small rear window, otherwise looks pretty much the same as the 67 69-Front of hood made steeper, aluminum double-slit grille with black plastic "egg crate" inserts, bowtie emblem on front of hood, lower bodyline trim made wider and no longer follows wheel arch, upper body trim added 70-Black plastic grille inserts have louvres on them, rear axle widened mid-year 71-Aluminum grille frame no longer has center bar, and egg-crate insert is much more pronounced, bowtie mounted in center of grille, front turn signals mounted in front bumper, 5-lug wheels, front disc brakes 72-Rear-view mirror glued to the windshield, plastic inner door panels, extra screw on inside of door just under vent window |
02-26-2006, 03:10 AM | #4 |
1967
02-26-2006, 03:11 AM | #5 |
1968
02-26-2006, 03:13 AM | #6 |
1969
02-26-2006, 03:14 AM | #7 |
1970
02-26-2006, 03:15 AM | #8 |
1971
02-26-2006, 03:15 AM | #9 |
1972
02-26-2006, 09:07 AM | #10 |
Could you be more specific what differences you`re debating?Basically,every two years the front-end styling changed,but that`s obvious.
02-26-2006, 11:27 AM | #11 |
Where's my beer?
you didn't mention if you was talking about chevy's or GMC's, GMC was a different animal and the grilles also changed throught the years, help us out.
Paul How do you make the invisible, visible?.........You take it away. |
02-26-2006, 11:28 AM | #12 |
Try this link: http://www.rayschevy.com/images/guides/ident/year.htm
Hook'em |
02-26-2006, 11:39 AM | #13 |
its all about the +6 inches
The longhorn info on rays chevy is inacurate. (His info was pirated, Just like most of the descriptions ont he web for these. Go looking around the web, and you'll find the exact same info, word for word everywhere else on the web)
That orange truck up there posing as a 69 has a 70 grill on it. |
02-26-2006, 12:33 PM | #14 | |
Hook'em |
02-26-2006, 11:46 AM | #15 |
The 67-72 Chevys are all identical.Just look at the headlight,see?
02-26-2006, 12:07 PM | #16 |
queston , being new at this and working off and on on mine , if there the same why is the radiator support on 67 and 68 same and 69 to 72 the same ......????
02-26-2006, 12:20 PM | #17 |
Insert Title Here
He was being sarcastic.... the supports are differet because the grills and the angle of the hoods are different
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
02-26-2006, 01:06 PM | #18 |
Understood... just don't want some one new to the game seeing bad info and making it the rule in there head. Like many people do after looking at the LMC catalog.
02-26-2006, 05:55 PM | #19 |
1969
02-26-2006, 05:55 PM | #20 |
1970
02-27-2006, 01:39 AM | #21 |
Im sorry I was not spefic in what I was looking for. PJ got me more than covered and I appreciate that. This board is always the right place to turn to.
Lenny
02-27-2006, 10:08 AM | #22 |
So,your friend didn`t notice the grilles were different?
