02-26-2006, 11:00 AM | #1 |
What to coat underside of cab with.
Hi Guys, Just finished welding in patch panels on my 71 GMC. I'm curious, what would I spray the underside of the cab with to protect it? Currently it has just the typical surface rust. I have Eastwoods rust encapsulator ordered but I assume it should have something sprayed over the top of it? What have some of you experienced guys done?
Thanks.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
02-26-2006, 12:57 PM | #2 |
Re: What to coat underside of cab with.
I used a a putty knife to remove all of the undercoating and dirt. Then used a wire wheel on a grinder to remove any loose rust. Then used a da sander with 80 grit to finish cleaning it up. I use a product called rust cure you spray it on and let it sit for 24 hours. I Epoxy primed the whole under side. Then I sprayed it with some sprayable bedliner. I had it tinted orange to match the color I am going to paint my truck.
02-26-2006, 02:12 PM | #3 |
I used a spray on bed liner. You can also brush it on if need be.
02-26-2006, 04:34 PM | #4 |
Life, Be In It.....
I just did a recent post asking the same thing. I was going to spray bed liner on the under side of my cab. I learned that the bedliner material in very FLAMIBLE. Some else on the board recomended Lizard Skin. It is a little expensive, but better than rinho liner or line x. I will be using Lizard Skin.
http://www.coollizard.com/
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
