Jostrans68
door mounting help!!!!!!!!!!
the plate on the cab bottom hinge fell in any ease way to fix
![]() former 67-72 now with a 96 silverado Last edited by jostrans68; 02-27-2006 at 05:50 PM. |
Re: door mounting help!!!!!!!!!!
Fell in where?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Jostrans68
where the bootom hinge mounts to cab is hollow
![]() former 67-72 now with a 96 silverado |
![]() Join Date: Jun 2002
Probably the easiest is to cut through the kick panel on the inside of the truck, that's an inaccessable area, but a common problem.
Once you cut out the kickpanel you should be able to figure out what you need to do. Good luck Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
Before you cut anything try using a piece of wire to fish it back up to where
you can get to it. It could not have fallen very far , not that much space to drop. |
Custer had a plan too.
BFM and slide it up
(Big F***ing Magnet)
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ![]() 05 Subaru Outback for mileage |
Jostrans68
tried magnet wire and all there is actually alot of space I cut a 1 in hole and reached around in there and gave it now has nuts and flat washers oh well it aligned of Thanks
