Old 02-27-2006, 07:07 PM   #1
70c10swb
no brain no headache
70c10swb's Avatar
Front crossmember...
Like an idiot, when i removed the front crossmember off my frame i tossed the bolts (they were junk anyway). Now its time to go back on and i would like to know what size the bolts were, leingth and width. Obviously i will be useing grade 8 hardware and this brings me to the next question, would it be smart to put lock tite on the threads or no, and also how much should torque them to?
thanks in advance
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 02-28-2006, 03:38 AM   #2
4x4Poet
Re: Front crossmember...
Uh, you removed the '70 2wd truck's bolt-in engine crossmember/suspension cradle or the front crossmember which I thought was riveted in there? Another truck?
I'm easily confused.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-28-2006, 06:51 PM   #3
70c10swb
70c10swb's Avatar
engine/ suspention cradle
1996 GMC Sierra z71
Old 02-28-2006, 11:08 PM   #4
70c10swb
70c10swb's Avatar
Bump
1996 GMC Sierra z71
Old 02-28-2006, 11:28 PM   #5
dougs69c10
dougs69c10's Avatar
not sure of the size, but locktite would be a great idea and common practice on bolts/nuts that arent removed often
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end
dougs69c10 is offline   Reply With Quote
Old 03-01-2006, 07:22 PM   #6
70c10swb
70c10swb's Avatar
nobody
1996 GMC Sierra z71
Old 03-01-2006, 10:22 PM   #7
Brento72
resU deretsigeR
Brento72's Avatar
YEEAAAAAAAHHH! I can help! I just replaced mine with 1/2" x 1" washer and lockwasher. I have about 3 threads hanging out the bottom of the nut. I took the old bolts to the hardware store and matched them up one by one per each size for my whole frame. There is plenty of room so if you want to go to 1 1/4" if your washers are thicker, no problem.
Brent
Brento72 is offline   Reply With Quote
Old 03-02-2006, 06:50 PM   #8
70c10swb
70c10swb's Avatar
thannnnnk you sir
1996 GMC Sierra z71
