03-03-2006, 12:48 AM | #1 |
67-72 Addict!
Quick easy mod (reverse lights)- pics
Recently Longhorn Man and matthufham explained a quick fix for my reverse lights not working since I've owned my truck. I took their advice and unplugged the harness from the switch, added a lighted rocker switch (I used a blue switch) to my shifter plate (Matt's idea and his pic ) and ran 2 new wires to the harness. Works like a charm!. Tonight I decided to take my new favorite tape (Nashua brand foil tape) and line the reverse light housings with the foil tape to create a reflective surface. I trimmed off the excess with a razor blade. This made the light brighter and more uniform . The other benefit is it makes the new lenses look better during the day also. The last pic is in my pitch dark garage. This tape is awesome stuff!. Very sticky, conforms to any shape and is rated for moisture and extreme temperatures. I bought it at Home Depot for about $4/roll.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 03-03-2006 at 12:54 AM. |
03-03-2006, 12:56 AM | #2 |
Re: Quick easy mod (reverse lights)- pics
Great idea and great job. Looks like one for the FAQ!
JKR
****Have you ever danced with the devil in the pale moonlight....I ask that of all my prey**** 68' C10 Short Step (rebuilding as we speak) 72' Custom Camper (wrecked, parting out) 79' C10 Fleet (rough, parting out) 97' C1500 Short Step Custom (DD) 97' Kawaski VN800a Customized 99' Z71 Silverado 04' Suzuki Volusia |
03-03-2006, 01:09 AM | #3 |
I bet this would be good for the tail lights also.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
03-03-2006, 01:11 AM | #4 |
Chevy truck addict
dude those are hella bright!
03-03-2006, 08:00 AM | #5 |
67-72 Addict!
sdkid- I'm running custom made LED tail lights that are very bright but I bet you are right. I'm planning a little test with my grille lights and side markers and I'll let everybody know how it turns out.
AesC10s- the pic makes them look brighter than they really are but it still made a nice difference. Took 5 minutes to do each socket.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-03-2006, 08:27 AM | #6 |
Looks great! This months street rod builder page 94 showed this for old modle A type lights. Looks like it would work real well.
Kevin Last edited by Rokcrln; 03-03-2006 at 08:29 AM. |
03-03-2006, 08:46 AM | #7 | |
67-72 Addict!
03-03-2006, 09:04 AM | #8 |
I had a switch like that for reverse lights on an old truck I had.Another cool feature is,you can flick the switch even when in drive.So tailgaters and dummies behind you with their brights on can be sent a real clear message.
03-03-2006, 09:12 AM | #9 | |
67-72 Addict!
03-03-2006, 10:01 AM | #10 | |
ion my old truck i had super bright fog lights mounted right behind the cab on the bed and when some one tailgating turn them on and blind them expect these killed my battery everytime i used them because my alternator wasn't strong enough to run them long
03-03-2006, 09:25 AM | #11 |
I just happen to have some of this tape laying around, as I am building a house at the moment.
I know what I will do this evening! Thanks for sharing!
Orange '71 GMC |
03-03-2006, 10:46 AM | #12 |
Was the switch in your shifter broke?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
03-03-2006, 10:49 AM | #13 |
English Chevy Owner
I have an old 55W spotlamp bolted on to the back of my Isuzu Trooper 4x4 as an extra reversing/worklight for off road use. Sure does stop tailgaters though! My truck has no reversing lights as they've been turned into amber UK spec turn signals as flashing red taillights is illegal over here.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
03-03-2006, 11:12 AM | #14 | |
03-03-2006, 11:58 AM | #15 |
67-72 Addict!
My column had been changed to a floor shifter type column and my switch in the floor shifter was removed by a former owner.
