![]() Join Date: Dec 1999
This was on the board a while back and I printed it out at the time so I would have it. But naturally I lost it somewhere. What Years and model of Cadillac can we scavange the rotors and calipers from for our trucks? Appreciate help from someone better organized or with a better memory! Thanks Smitty!
Smitty '71 Short Fleetside Spring Valley, Ca. |
Vortec 350's Suck
77-79 Cadillac Seville are the easiest swap, cause the cars are rear wheel drive to begine with. The same age and up to 83 Riveria's, Toronados and 80 up(all fwd) Sevilles will work too, but you have to fab an backer plate. I remember I mailed you pictures of my diff and how it is setup a while back, lost those though I assume.
69 Chev CST 10 reg cab lwb Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03 Will be resurrected |
Resident Young Old Dude !
CHEVYMAN69,
Would you share those pictures with me ? That's a change I would like to do in the near future. I just went to front disc. conversion kit. RON. PEGASUS@USINTOUCH.COM |
Guys, go here. www.off-road.com/chevy/reviews/tsm/
There are several members of www.pirate4x4.com that sell the brackets or you can make your own using front backing plates. If you need drawings, pm me.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's mine on my 71 Blazer,12 bolt rear end,6 lug.
![]() You can check out pic's of the full install here
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() Join Date: Apr 2000
Can you tell any differance in the stopping with the rear disc.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
I thought it would be alot better...but it isn't(for me).I run 33" tires so that prob. has something to do with it.Performance would prob. be better with tires that are closer to stock.My system doesn't seem to be dialed in right.There are guys who have 4 wheel disc's on our year truck who can stop on a dime.
does any machine work have to be done to the axles to make the rotors fit over the centering hub?
No, Its not a 454 |
YES on the Cadillac conversion......the center hub and the outer flange (where the lugs go through) have to be turned down.
I can't say on the other conversions. here is a pic of the cadillac seville converson. |
